Allow users to have multiple rdp sessions?
Testing haproxy as a load balancing tool to our 4 2008 R2 terminal servers.
It’s working ok except that I can’t work out how to let staff have more than one simultaneous rdp session. At present if they start a second rdp session from a different device haproxy always connects them to their existing session. I can understand why this is happening as the hash is seeing the user name but I’d like users to be allowed 2 different rdp server sessions simultaneously.
Does anyone know how to acheive this with ha proxy?
Many thanks,
Greg.
Can you post your haproxy.cfg file ?
maxconn 40000
ulimit-n 81001
timeout client 50000000
timeout server 50000000
stats uri /
stats hide-version
option httpclose
frontend F1
bind 10.99.122.100:3389
maxconn 40000
default_backend B1
backend B1
option tcpka
tcp-request content accept if RDP_COOKIE
persist rdp-cookie
stick-table type string size 204800 expire 1d
stick on rdp_cookie(mstshash)
clitimeout 2h
server SCULTS9 10.99.122.4:3389 weight 1 check port 3389 inter 2000 rise 2 fall 3 minconn 0 maxconn o on-marked-down shutdown-sessions
server SCULTS10 10.99.122.6:3389 weight 1 check port 3389 inter 2000 rise 2 fall 3 minconn 0 maxconn o on-marked-down shutdown-sessions
server SCULTS11 10.99.122.8:3389 weight 1 check port 3389 inter 2000 rise 2 fall 3 minconn 0 maxconn o on-marked-down shutdown-sessions
server SCULTS12 10.99.122.10:3389 weight 1 check port 3389 inter 2000 rise 2 fall 3 minconn 0 maxconn o on-marked-down shutdown-sessions
option abortonclose
persist rdp-cookie
#balance rdp-cookie
     bind 10.99.122.100:8181
     stats uri /
     stats auth username:password
