Force http to https
Hi Team,
I’m trying to force https on my test website. I have the following config “haproxy > Nginx > Tomcat”. However whenever I add “redirect scheme https if !{ ssl_fc }” to force https my login stops. Currently, both http and https are working well individually. The following is my configuration. I have separate frontend & backend for http and https. Not sure where I am going wrong. Please help!!
frontend http-test-80
bind 192.168.1.10:80
    acl host_test80 hdr(host) -i test.zahid.com
    use_backend static_test if host_test80
    acl host_test80 hdr(host) -i static1.test.zahid.com
backend static_test
option httpclose
cookie static insert indirect nocache
option httpchk HEAD /LoadBalancer_HealthCheck.php HTTP/1.0
server stat-test 192.168.1.20:80 cookie mpstatic1 check
frontend http-test-443
bind 192.168.1.10:443 ssl crt /etc/haproxy/certs/test.zahid.com/test.zahid.com.pem
    acl host_test443_secure hdr(host) -i test.zahid.com
    use_backend static_test_secure if host_test443_secure
    acl host_test443_secure hdr(host) -i static1.test.zahid.com
option httpclose
server stat-test-secure 192.168.1.20:80 cookie mpstatic2 check
Best Regards,
Zahid
Do you have multiple backend servers or is there just one, as per the configuration you provided?
I suggest you use the same backend for both frontends. Especially the fact the same server has a different cookie value is problematic.
Hi lukastribus,
Thanks for your reply!!
No just one backend server (nginx).
Okay so if I use same backend for both frontends then should my config look like the following. Please correct me if any config mistakes:
use_backend static_test_secure if host_test80
option httpclose
server stat-test-secure 192.168.1.20:80 cookie mpstatic1 check
Then why do you configure roundrobin, heatlh checks and cookie stickiness? That makes no sense with only one backend server.
Elaborate what that means exactly please.
Hi lukastribus,
Actually, earlier I was using two servers in backend and hence the settings you’ve pointed out but now i’ve decided to continue with only one backend server and I haven’t disturbed the earlier settings.
Best Regards,
Zahid
Hi lukastribus,
I’ve disabled roundrobin, heatlh checks and cookie stickiness but still i’m unable to login. once I remove “redirect scheme https if !{ ssl_fc }” from port 80 frondend i am able to login.
Best Regards,
Zahid
