We’re running the latest 1.5.19 version of HAProxy and have been seeing segfaults since the introduction of a stick table needed to rate limit requests to our ‘login’ endpoint. We have attackers hitting this at around 1200 req/min. Regardless if there’s a current attack, haproxy will crash several times a day, and logs this-
kernel: haproxy[11890]: segfault at 9695000 ip 00007fc839165701 sp 00007ffc748e6a68 error 4 in libc-2.17.so[7fc839016000+1b7000]
Below is the stick table culprit. We know this, because if we comment these lines out, no more crashes. Seems like a pretty simple table, not a lot of room for misconfiguration… This is located in the backend section of our config.
stick-table type ip size 200k expire 5m store gpc0,conn_cur,conn_cnt
acl block_on_path path_beg -i /path/to/login
tcp-request content track-sc1 src if block_on_path
http-request tarpit if { src_conn_cnt ge 15 } block_on_path
If I look at this table at any random time, it seems to average around 4k of the 200k table size, so I think we’re probably not filling up our table. Memory/CPU are not a problem. Under an attack, the CPU load can go up to around 80%, no concerns there yet. Here’s the table as I write this -
Every 1.0s: echo “show table jboss7_cluster” | sudo socat unix:/var/run/haproxy.stats - Fri Mar 10 19:19:13 2017
table: jboss7_cluster, type: ip, size:204800, used:3127
0x9ef249c: key=1.10.199.35 use=0 exp=2045 gpc0=0 conn_cnt=1 conn_cur=0
0x3c0b89c: key=1.10.199.93 use=0 exp=271280 gpc0=0 conn_cnt=1 conn_cur=0
0x9c9c25c: key=1.32.24.54 use=0 exp=75902 gpc0=0 conn_cnt=1 conn_cur=0
0x460fcbc: key=1.33.107.79 use=0 exp=19818 gpc0=0 conn_cnt=1 conn_cur=0
0x402743c: key=1.52.1.57 use=0 exp=251825 gpc0=0 conn_cnt=1 conn_cur=0
0x2b475cc: key=1.52.240.156 use=0 exp=273221 gpc0=0 conn_cnt=1 conn_cur=0
0xab204bc: key=1.53.181.46 use=0 exp=176877 gpc0=0 conn_cnt=1 conn_cur=0
0x39dbd4c: key=1.54.218.41 use=0 exp=132587 gpc0=0 conn_cnt=1 conn_cur=0
0x2c4a1cc: key=1.55.119.221 use=0 exp=278489 gpc0=0 conn_cnt=1 conn_cur=0
0x75531dc: key=1.224.148.65 use=0 exp=24270 gpc0=0 conn_cnt=1 conn_cur=0
0x6ffb12c: key=1.226.133.132 use=0 exp=164417 gpc0=0 conn_cnt=1 conn_cur=0
0x753220c: key=1.228.23.251 use=0 exp=8600 gpc0=0 conn_cnt=1 conn_cur=0
0x8faf35c: key=1.231.28.2 use=0 exp=293120 gpc0=0 conn_cnt=1 conn_cur=0
0x97e6aac: key=1.232.77.49 use=0 exp=277764 gpc0=0 conn_cnt=1 conn_cur=0
0x3ad418c: key=1.234.141.109 use=0 exp=161023 gpc0=0 conn_cnt=1 conn_cur=0
0x5cb6a8c: key=1.234.144.6 use=0 exp=161278 gpc0=0 conn_cnt=1 conn_cur=0
0x6f0615c: key=1.239.51.214 use=0 exp=279495 gpc0=0 conn_cnt=1 conn_cur=0
0x581343c: key=1.241.19.72 use=0 exp=12058 gpc0=0 conn_cnt=1 conn_cur=0
0x3f9da1c: key=1.252.206.152 use=0 exp=128317 gpc0=0 conn_cnt=1 conn_cur=0
0x351aa3c: key=2.30.243.70 use=0 exp=275506 gpc0=0 conn_cnt=1 conn_cur=0
0xaf3e09c: key=2.32.215.93 use=0 exp=45313 gpc0=0 conn_cnt=1 conn_cur=0
0x9968b1c: key=2.50.152.32 use=0 exp=282299 gpc0=0 conn_cnt=1 conn_cur=0
0x329a0bc: key=2.50.213.122 use=0 exp=183950 gpc0=0 conn_cnt=1 conn_cur=0
0x672051c: key=2.86.52.175 use=0 exp=209063 gpc0=0 conn_cnt=1 conn_cur=0
0x9a6cb5c: key=2.88.139.155 use=0 exp=26832 gpc0=0 conn_cnt=1 conn_cur=0
0x43f2c9c: key=2.91.241.189 use=0 exp=278143 gpc0=0 conn_cnt=1 conn_cur=0
0x29f456c: key=2.95.242.245 use=0 exp=145829 gpc0=0 conn_cnt=1 conn_cur=0
0x900cbfc: key=2.98.44.25 use=0 exp=156035 gpc0=0 conn_cnt=1 conn_cur=0
0x7451ccc: key=2.186.216.19 use=0 exp=186612 gpc0=0 conn_cnt=1 conn_cur=0
0x821808c: key=2.230.145.122 use=0 exp=171511 gpc0=0 conn_cnt=1 conn_cur=0
0x82070cc: key=5.12.16.130 use=0 exp=4488 gpc0=0 conn_cnt=1 conn_cur=0
0x540e29c: key=5.15.211.19 use=0 exp=63660 gpc0=0 conn_cnt=1 conn_cur=0
I’d be happy to post any additional log info requested. Thanks in advance!
HAP
