Hi all
Im using moodle, the user log into Moodle and navigate, but after 3 or 4 minuts the sesion closed and need to login again, every 3 or 4 minuts always.
I tried to modify diferente parameters
log 127.0.0.1 local2 #Log configuration
pidfile /var/run/haproxy.pid
maxconn 4000
user haproxy #Haproxy running under user and group "haproxy"
# turn on stats unix socket
#option http-server-close
##option forwardfor except 127.0.0.0/8
##option redispatch
##retries 3
##timeout http-request 10s
##timeout queue 20s
timeout connect 2s
timeout client 10m #La sesion se cierra tras x inactividad del cliente
timeout server 20m #El servidor cierra tu conexión en sin importar el cambio de página
##timeout http-keep-alive 30m #La sesion se cierra tras x inactividad
##timeout check 20m
maxconn 3000
balance source
listen haproxy3-monitoring *:8080 #Haproxy Monitoring run on port 8080
##option forwardfor
#option httpclose
##option http-server-close
stats show-legends
stats refresh 5s
stats uri /statsx #URL for HAProxy monitoring
stats auth stats:123pormi #User and Password for login to the monitoring dashboard
stats admin if TRUE
stats auth admin:pass
frontend public
##default_backend app-main
###ACL
acl adistanciaBackend hdr_beg(host) -i adistancia.
acl appsBackend hdr_beg(host) -i apps.
acl wwwBackend hdr_beg(host) -i www.
use_backend adistancia if adistanciaBackend
##use_backend apps if appsBackend
##use_backend www if wwwBackend
##backend app-main
balance roundrobin #Balance algorithm
## option httpchk HEAD / HTTP/1.1\r\nHost:\ localhost #Check the serveris up and healty - 200 status code
###server ciclope 192.168.2.94:80 check
##server vulcano 192.168.2.96:80 check
backend adistancia
#balance source #Balance algorithm
cookie SERVERID insert indirect
##cookie SERVERID rewrite maxlife 120m
##cookie SERVERID prefix nocache maxlife 33m
server vulcano 192.168.2.96:80 check cookie vulcano
##backend apps
##option httpchk HEAD / HTTP/1.1\r\nHost:\ localhost #Check the serveris up and healty - 200 status code
##cookie SERVERID insert indirect nocache
##server vulcano 192.168.2.96:80 check cookie vulcano
###server ciclope 192.168.2.94:80 check cookie ciclope
backend www
