Haproxy - httpd real ip
I just installed haproxy as reverse proxy for apache under centos 7.
I configured it to do ssl from end to end (client ← ssl → haproxy ← ssl → srv_web).
Everything works, the only problem is that at the level of logs apache, it is impossible to have the IP address of the client.
My configuration:
frontend http-in
acl acl1 hdr(host) domain.fr
use_backend back1 if acl1
frontend https-in
bind *:443 ssl crt cert.pem no-sslv3
backend back1
option httpchk
option forwardfor header X-Client
server web-server1 10.10.0.1:8443 ssl verify none
In apache : httpd.conf
LogFormat “%{X-Forwarded-For}i %l %u %t "%r" %>s %b "%{Referer}i" "%{User-Agent}i"” combined
Would anyone have an idea?
Thank you in advance
Looks like you configured haproxy to send the client IP in the header X-Client, but Apache expects X-Forwarded-For.
Remove “header X-Client” from the “option forwardfor” directive.
Thank you for your answer.
I deleted the line, but nothing changes. It does not always work.
Other ideas?
Which haproxy release is it?
In 1.4 you need
http://cbonte.github.io/haproxy-dconv/1.5/configuration.html#option%20http-server-close
