Haproxy multiple processes after reload
We experienced this recent issue with haproxy where multiple haproxy processes were spawned after a reload. We use the following haproxy build:
HA-Proxy version 1.5-dev25-a339395 2014/05/10
Copyright 2000-2014 Willy Tarreau w@1wt.eu
TARGET = linux26
CC = gcc
CFLAGS = -m64 -march=x86-64 -O2 -g -fno-strict-aliasing
OPTIONS = USE_OPENSSL=1 USE_PCRE=1
Built without zlib support (USE_ZLIB not set)
Compression algorithms supported : identity
Built with PCRE version : 7.8 2008-09-05
Built with transparent proxy support using: IP_TRANSPARENT IP_FREEBIND
We are passing the soft reset option(-sf ) during haproxy reload. Out of the blue we found multiple haproxy procs serving requests actively. We had to terminate them by manually passing SIGUSR1 signal to each of the rogue processes.
Doesn’t haproxy pass SIGUSR1 automatically while we do a reload? If no , what could be done to avoid such an issue?
–Thanks
Sarath.K
This is a more than 2 year old development build, it is not a stable release and it is not supported.
Upgrade to latest stable 1.5 or 1.6 haproxy release.
This issue may be a bug in the ancient code you are using, or an issue with the PID file. Upgrade the code, and check for PID file issues.
