HAProxy SSL offloading/termination
Hello everyone,
I’m trying to setup HAProxy with SSL offloading/termination.
Basically I have HAProxy in front of a Docker Container where is running WebLogic.
This is my configuration :
ca-base /etc/pki/tls/certs
crt-base /etc/pki/tls/certs
log localhost local0
maxconn 2000
ssl-server-verify none
maxconn 2000
option log-separate-errors
timeout http-request 5s
timeout queue 50000
timeout check 10s
bind *:1936 ssl crt /etc/haproxy/full_cert_host_v2.pem
stats hide-version
stats uri /haproxy?stats
stats refresh 10s
stats show-legends
listen weblogic
bind :10000 ssl crt /etc/haproxy/full_cert_host_v2.pem
cookie JSESSIONID prefix indirect nocache
maxconn 2002
option httpchk HEAD /console
timeout check 10s
timeout http-keep-alive 3000
server 172.17.0.2 172.17.0.2:8001 cookie 172.17.0.2 maxconn 256 check inter 2000 rise 2 fall 5.
When I try to connect to https:// host:10000/console I have this :
[root@host haproxy]# wget https:// host:10000/console
–2017-03-31 16:29:57-- https:// host:10000/console
Resolving host (host)… host, hostIPv6
Connecting to host (host)|host|:10000… connected.
HTTP request sent, awaiting response… 302 Moved Temporarily
–2017-03-31 16:29:57-- http:// host:10000/console/
HTTP request sent, awaiting response… No data received.
Retrying.
instead if I try direct to access to the container I obtain something like that :
[root@host haproxy]# wget 172.17.0.2:8001/console
–2017-03-31 16:34:04-- http:// 172.17.0.2:8001/console
Connecting to 172.17.0.2:8001… connected.
–2017-03-31 16:34:04-- http:// 172.17.0.2:8001/console/
Reusing existing connection to 172.17.0.2:8001.
Location: http:// 172.17.0.2:8001/console/login/LoginForm.jsp [following]
–2017-03-31 16:34:04-- http:// 172.17.0.2:8001/console/login/LoginForm.jsp
HTTP request sent, awaiting response… 200 OK
Someone could help to figure out how fix it ?
Thank you a lot!
Cheers,
Antonio
Your backend redirects from HTTPS to HTTP, at which point haproxy it no longers works (of corse HTTP on port 10000 is not available, this is a HTTPS port only). Find out why your backend emits a redirect to HTTP and fix it.
