HAProxy Stats over HTTPS only
hi,
Absolutely new to HAProxy and I am trying to get the HAProxy stats over https. As a matter of fact I want HAProxy stats to be accessible ‘only’ over https. Can anyone give me some pointers? The current config is shown below and works well on port 8888 but I need it over SSL. I have created the .pem certificate too
listen mariadb_cluster_writes 0.0.0.0:12206
## A failover pool for writes to ensure writes only hit one node at a time.
        option httpchk
        server node_1 192.168.xxx.xxx:3306 check port 9200
        server node_2 192.168.xxx.xxx:3306 check port 9200 backup
        server node_3 192.168.xxx.xxx:3306 check port 9200 backup
listen mariadb_cluster_reads 0.0.0.0:12208
## A load-balanced pool for reads to utilize all nodes for reads.
        option httpchk
listen stats 0.0.0.0:8888
## HAProxy stats web gui.
	stats hide-version
	stats uri /haproxy_stats
	stats auth haproxy:haproxy
	stats admin if TRUE
Thanks,
R.W
Don’t specify the listening socket on the listen line, but use a dedicated bind statement. Then you can enable all SSL options you like.
	bind 0.0.0.0:8888 ssl crt /bla/ble/cert.pem
thanks @lukastribus, let me give that a try
hi, it works but that brings me to another little question - how do I enable HSTS in HAProxy 1.5? My haproxy.cfg goes like this
	bind 0.0.0.0:443 ssl crt /etc/ssl/dblb.testcert.com.combined.pem no-sslv3 ciphers ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS
##	stats hide-version
	stats auth admin:admin_pwd
	stats admin if TRUE
Thanks once again for the help
Cheers,
R.W
@lukastribus thanks…I found that last night and it helped! :slight_smile:
Thanks for all the help
