HTTP and TXN classes
Dear friends, i need help.
I want to use lua scripting. In particular, i’m interested HTTP class. My target is manipulation response. Example:
local headers = txn.http:req_get_headers()
local host = headers[“host”][0]
txn.http:res_add_header(“X-Custom-Header”, host)
but this header dosen’t set to response. The locate in register_action.
What is it not right?
Also i’m interested txn.set_var method. I want to set many variable for config file. I did so:
txn.set_var(“var1”,“value 1”)
but i can’t use the variable in haproxy.cfg. Please, if it possible, give me something example.
you must add this header in the response in a section processing the response, like
http-response lua.XXX
Thierry
