Hi All,
Previously i’m apologize if wrong discuss my issue in here, i’m new on haproxy.
I have issue on my haproxy. I plan make cluster with haproxy for SMTP (postfix/25), Webserver (httpd/80) and Resolver DNS (Bind/53).
I’m running for smtp and web it’s work but have problem in dns resolver.
Could you help me for suggestion problem solving this issue?
Below log on my haproxy
smtp (works)
Apr 4 13:53:47 localhost haproxy[8979]: 50.50.50.5:51186 [04/Apr/2018:13:53:46.685] ft_smtp bk_postfix/smtp007-2 1/0/475 368 – 0/0/0/0/0 0/0
Apr 4 13:55:51 localhost haproxy[8979]: 50.50.50.5:51191 [04/Apr/2018:13:55:50.630] ft_smtp bk_postfix/smtp007-1 1/0/398 367 – 0/0/0/0/0 0/0
httpd (works)
Apr 4 13:51:25 localhost haproxy[8979]: 50.50.50.5:51183 [04/Apr/2018:13:51:25.899] ft_web bk_web/syslog-smtp007 1/4/44 18673 – 0/0/0/0/0 0/0
dns (not works)
Apr 4 13:54:50 localhost haproxy[8979]: 50.50.50.5:51189 [04/Apr/2018:13:54:20.696] ft_dns bk_bind/rdns007-1 1/0/30002 0 – 0/0/0/0/0 0/0
Apr 4 13:55:41 localhost haproxy[8979]: 50.50.50.5:51190 [04/Apr/2018:13:55:11.142] ft_dns bk_bind/rdns007-2 1/0/30013 0 – 0/0/0/0/0 0/0
Below my configuration haproxy.cfg:
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 3000
frontend ft_smtp
bind 10.10.10.5:25
no option http-server-close
timeout client 1m
maxconn 3000
default_backend bk_postfix
backend bk_postfix
timeout server 1m
timeout connect 30s
server smtp007-1 20.20.20.5:315 check
server smtp007-2 20.20.20.6:317 check
frontend ft_web
bind 10.10.10.5:80
timeout client 1m
maxconn 3000
default_backend bk_web
backend bk_web
timeout server 1m
timeout connect 30s
server syslog-smtp007 30.30.30.4:80 check
frontend ft_dns
bind 10.10.10.5:53
timeout client 1m
maxconn 3000
default_backend bk_bind
backend bk_bind
timeout server 1m
timeout connect 30s
server rdns007-1 40.40.40.2:53 check
server rdns007-2 40.40.40.3:53 check
Below my test use my dns resolver
haproxy007 ~]# nslookup
server 40.40.40.2
Default server: 40.40.40.2
Address: 40.40.40.2#53
google.com
Server: 40.40.40.2
Non-authoritative answer:
Address: 74.125.68.101
Address: 74.125.68.102
Address: 74.125.68.113
Address: 74.125.68.138
Address: 74.125.68.100
Address: 74.125.68.139
server 40.40.40.3
Default server: 40.40.40.3
Address: 40.40.40.3#53
google.com
Server: 40.40.40.3
Address: 74.125.24.139
Address: 74.125.24.100
Address: 74.125.24.113
Address: 74.125.24.101
Address: 74.125.24.102
Address: 74.125.24.138
server 10.10.10.5
Default server: 10.10.10.5
Address: 10.10.10.5#53
google.com
;; connection timed out; trying next origin
;; connection timed out; no servers could be reached
Above if i’m use child my dns resolver it’s work but if i’m use on parrent haproxy problem.
Below I’m test telnet ip parrent haproxy on listen port 53 dns connected:
haproxy007 ~]# telnet 10.10.10.5 53
Trying 10.10.10.5…
Connected to 10.10.10.5.
Escape character is ‘^]’.
quit
Connection closed by foreign host.
And haproxy log :
Apr 5 11:33:07 localhost haproxy[31732]: 10.10.10.5:53274 [05/Apr/2018:11:32:37.234] ft_dns bk_dns/rdns007-2 1/0/30001 0 – 0/0/0/0/0 0/0
Apr 5 11:33:40 localhost haproxy[31732]: 10.10.10.5:53442 [05/Apr/2018:11:33:10.137] ft_dns bk_dns/rdns007-1 1/0/30001 0 – 0/0/0/0/0 0/0
haproxy007 ~]# haproxy -v
Please tell me if you need another information or log on my haproxy.
I’m so appreciate for your help and replies for advice my problem.
Regards,
Andrian
