I’ve a haproxy setup with tcp mode ssl configuration [ to offload ssl sockets traffic]. But Socket is not connecting from Chrome 56 browser. Whereas site loading fine on previous version like Chrome 55.
Note : site running with RapidSSL certificate
I don’t see any error in HAproxy logs. But in front end, connection is dropped. I just capture Alert message on sniffer, after that connection closed in browser.
Request Type: Secure SSL socket from Adobe flash player
Built with OpenSSL version : OpenSSL 1.0.2h 3 May 2016
Running on OpenSSL version : OpenSSL 1.0.2h 3 May 2016
Built with PCRE version : 6.6 06-Feb-2006
Built without Lua support
So you are using SSL client certificates? Are those correctly configured in chrome?
Can you try without it?
The frontend name is strange, please set it to a proper name, not ip:port. It is confusing otherwise and it a different context (a listen directive) simply wrong.
I’m afraid there are no enough informations here to understand the issue. Unless you can share more informations, its gonna be though to find the root cause.
