Hi
I’m having 2 issues with below systemctl script with RHEL 7.X
- I’m seeing below error frequently in systemctl status haproxy-80 or 443 instance
systemd[1]: [/etc/systemd/system/haproxy-80.service:11] Failed to parse kill mode, ignoring: mixed
- More importantly, after few days HAPROXY unable respond and health checks are failing. I am pretty sure backend is working fine. restarting the haproxy immediately fixing the issue. There is no pattern but it has been happening very frequently. As always, restarting haproxy resolving the issue immediately
I am using a self compiled version of haproxy and below are compiled flags
HA-Proxy version 1.6.8 2016/08/14
TARGET = linux2628
CPU = native
CC = gcc
CFLAGS = -O2 -march=native -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_LIBCRYPT=1 USE_ZLIB=yes USE_OPENSSL=1 USE_STATIC_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2h 3 May 2016
Running on OpenSSL version : OpenSSL 1.0.2h 3 May 2016
Built without Lua support
My systemctl startup script
cat /etc/systemd/system/haproxy-80.service
[Unit]
After=syslog.target network.target
[Service]
Environment=“CONFIG=/opt/haproxy/haproxy-80/conf/haproxy.conf” "PIDFILE=/run/haproxy-80.pid"
ExecStartPre=/opt/haproxy/haproxy-80/sbin/haproxy-80 -f $CONFIG -c -q
ExecStart=/opt/haproxy/haproxy-80/sbin/haproxy-80-systemd-wrapper -f $CONFIG -p $PIDFILE
ExecReload=/opt/haproxy/haproxy-80/sbin/haproxy-80 -f $CONFIG -c -q
KillMode=mixed
Restart=always
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=haproxy-80
Environment=NODE_ENV=production
[Install]
WantedBy=multi-user.target
.i am running 80 and 443 instances separately thus. binaries are shared but using different configuration files.
Can you confirm above systemctl startup script is valid ?
Srinivas Kotaru
