Haproxy version: 2.1.4
I am getting the below errors continuously.
OpenSSL error[0x14228044] construct_ca_names: internal error
I browsed through the internet and got this
https://mta.openssl.org/pipermail/openssl-users/2018-October/009003.html
Any help is appreciated.
in continuation with the OpenSSL error - construct_ca_names , tried the following option no-ca-names, https://cbonte.github.io/haproxy-dconv/1.8/configuration.html#5.1-no-ca-names
Any side affect of using this configuration… when should one use/not use it?
Share the configuration, the output of haproxy -vv and explain what you are trying to achieve.
I don’t have a clue about what you are trying to achieve, maybe start with the basics here?
@lukastribus please find the details here
haproxy -vv haproxy.cfg
HA-Proxy version 2.1.4 2020/04/02 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2021.
Known bugs: http://www.haproxy.org/bugs/bugs-2.1.4.html
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Running on OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Built with PCRE2 version : 10.32 2018-09-10
: mode=HTTP side=FE|BE mux=H1
Available services :
prometheus-exporter
[FCGI] fcgi-app
haproxy.cfg
log /Users/abhay/_log local0 debug
stats socket /Users/abhay/haproxy.sock level admin
ca-base /Users/abhay/server
crt-base /Users/abhay/server
tune.ssl.cachesize 0
tune.bufsize 16384
tune.maxrewrite 1024
spread-checks 4
nbproc 2
option log-health-checks
log /dev/log local6
timeout client 30s
timeout server 30s
frontend website
bind :8998 ssl crt server.pem ca-file root.pem verify
default_backend goserver
backend goserver
option httpchk GET /
server server1 127.0.0.1:8999 check maxconn 30
The root.pem contains close to 400 entries. When the clients are connected the haproxy errors out with the
Figured out that when the certs were brought down to 381 things just worked fine. Upon searching on the internet, I found this open ssl url
Modified the configuration above and used no-ca-names in the configuration
frontend website
bind :8998 ssl crt server.pem no-ca-names ca-file root.pem verify
Things are working just fine.
However I am not sure what are the other side affects of using no-ca-names .
I want to understand if the usage is right and if I will not run into any other issues? The haproxy documentation doesn’t have enough details
Why would you every have 400 entries in the CA file? A CA file is supposed to have a single certificate in there.
