Retrieving assets using an extremely simple configuration takes 10 times longer than when wget is used to retrieve the same asset from the same machine. What can be tuned to alleviate this? Load on the machine is practically zero, CPU usage never worth noting
With this level of information you are certain that nobody will be able to help you.
