I have a common frontend that accepts connections from our external gateway and routes them to backends:
frontend https-rev-auth
bind [::]:443 crt /etc/haproxy/ssl/fauth/ alpn h2,http/1.1
# Additional variables used later
http-request set-var-fmt(req._someVar) ....
# Direct to error page if source doesn't match
use_backend _forbidden unless { src -f /etc/haproxy/cloudflare.lst }
# Route request
default_backend _deny-no-match
use_backend foo-app if { hdr(host) -i foo.example.com }
use_backend bar-app if { hdr(host) -i bar.example.com }
use_backend baz-app if { hdr(host) -i baz.example.com }
backend foo-app
server web1 foo-app-srv:1234 check inter 10s
Now I need to add authentication where client would either have to arrive with Authorization: Basic ...
or a valid JWT token for a given application. The backend will then receive a custom header with authenticated username, regardless of whether the user used JWT or HTTP auth.
However, just the JWT validation is very heavy, and thus I want to only do it for a few endpoints where I expect JWT at all.
I know I can do something stupid like below, but this sends the request on a long and expensive journey, and duplicates my host list:
use_backend baz-app if { hdr(host) -i baz.example.com } # non-JWT app
use_backend _force-jwt if { hdr(host) -i abc.example.com } # direct to "shin" JWT backend
use_backend _force-jwt if { hdr(host) -i def.example.com }
backend _force-jwt
server jwt 127.0.0.1:99999
frontend jwt
bind 127.0.0.1:9999
http-request deny content-type 'text/html' string 'Missing Authorization HTTP header' unless { req.hdr(authorization) -m found }
http-request deny content-type 'text/html' string 'JWT has expired' if { var(txn.exp),sub(txn.now) -m int lt 0 }
# Direct to a real app server backend
use_backend abc-app if { hdr(host) -i abc.example.com }
use_backend def-app if { hdr(host) -i def.example.com }
Is there a smarter way to, I guess, generically apply a set of expensive ACLs to only a subset of hosts that arrive through a frontend? I tried searching with various keywords and I wasn’t able to find a smart solution.
