First https connection fails, second works
I have HAPROXY on pfsense and have the following issue:
I load balance 443 over 2 web servers using round robin. but i have the following issue:
when the guys doing API calls, the first call ALWAYS fails '(timeout) but the second works!
I have no idea why. could someone help?
1:1 NAT ------------
External: EXT_IP_A
Internal: INT_SRV_A
Interface: lan/optX
Description: “Service A”
  1. Outbound NAT is automatic.
  2. NAT reflection:
    • enablebinatreflection=yes
    • enablenatreflectionhelper=yes
    • disablenatreflection=yes
VIP_A: EXT_IP_A/32 (CARP) – “Service A VIP”
mode = carp
  1. advskew = 0
  2. advbase = 1
frontend FE_SERVICE_A_443
bind EXT_IP_A:443
default_backend BE_SERVICE_A_443
option tcp-check
server srv1 INT_SRV_A1:443 check
server srv2 INT_SRV_A2:443 check
stick-table type ip size 50k expire 1h
stick on src
  • transparent_clientip = yes
  • transparent_interface = opt2|opt3|lan
Environment:
  • pfSense with HAProxy package
  • Several CARP VIPs terminating TCP/443
  • Frontends bind VIPs directly
  • Backends are internal servers (multiple nodes) with TCP/443
  • Mode: tcp
  • stick-table enabled (source IP)
  • Health checks: TCP or HTTP GET /api/v1/healthcheck
  • 1:1 NAT is used for inbound traffic (multiple EXT_IP → INT_IP mappings)
where could my issue be
