We recently upgraded to haproxy 1.7.9 , we are facing one issue.
A TLS tunnel is created from frontend system to haproxy and then haproxy creates a TCP connection with another interface after TLS handshake with frontend.
Here after TLS handshake haproxy hangs at getsockopt() system call.
0.000058 getsockopt(2, SOL_IP, 0x50 /* IP_??? */,
earlier we were using 1.5.19 and it was working fine.
Compression algorithms supported : identity(“identity”), deflate(“deflate”), raw -deflate(“deflate”), gzip(“gzip”)
Built with OpenSSL version : OpenSSL 1.0.2n 7 Dec 2017
Running on OpenSSL version : OpenSSL 1.0.2n 7 Dec 2017
Built with PCRE version : 8.41 2017-07-05
Running on PCRE version : 8.41 2017-07-05
Built without Lua support
Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT IP_F REEBIND
uname -a
Linux LB-0 4.4.118-pc64-distro.git-18.2.2-rcp2 #1 SMP Tue Feb 27 07:57:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
