Haproxy 1.9.0 segfault at 7f141e6e3ab8 ip 00007f141e6e3ab8 sp 00007ffea3eab4b8 error 15 in libc-2.17.so[7f141e6e3000+2000]
Please can you try again with the patches from this patch (to be applied to a naked master) : http://people.freebsd.org/~cognet/haproxy-patches.tar.gz
Thanks!
Hi Willy, the latest patch works fine now. Seems that the “0005-MEDIUM-servers-Be-smarter-when-switching-connections.patch” solve our coredump problem.
Everything’s back to normal with us.
Tks so much.
thank you, the patches were merged into master now. They’ll be backported into the next 1.9 (very soon hopefully).
I believe I’m suffering from similar errors using HAProxy for ssl termination—I see similar segfaults with similar error codes in syslog. I’m running Ubunut 16.04LTS and using the haproxy package by Vincent Bernat (via the debian team site), so I don’t know how useful I’ll be if you guys need any additional information.
It sounds like if my issue is the same as @safari, I should just sit tight and wait for the fix to show up in 1.9 stable and for the package maintainer to update the package from there.
If you guys need/want me to submit any logs or troubleshooting info, please let me know—happy to help in any way possible.
We’ve fixed a significant number of bugs and I’ll emit 1.9.1 on tuesday 8th, please try again with it (or right now with the 1.9 maintenance branch if you want).
1.8.17 and 1.9.1 have been released with the fix for this bug.
@lukastribus still crashing
[14516844.371937] haproxy[32302]: segfault at 8 ip 000000000042aca5 sp 00007ffdfd1dbef0 error 4 in haproxy[400000+183000]
[14516844.474076] haproxy[32303]: segfault at 8 ip 000000000042aca5 sp 00007ffdfd1dbef0 error 4 in haproxy[400000+183000]
[14516844.610569] haproxy[32304]: segfault at 8 ip 000000000042aca5 sp 00007ffdfd1dbef0 error 4 in haproxy[400000+183000]
[14516844.719870] haproxy[32301]: segfault at 8 ip 000000000042aca5 sp 00007ffdfd1dbef0 error 4 in haproxy[400000+183000]
[14516915.466312] haproxy[32478]: segfault at 8 ip 000000000042aca5 sp 00007ffd34174aa0 error 4 in haproxy[400000+183000]
[14516941.380339] haproxy[32588]: segfault at 8 ip 00000000004f70ee sp 00007fffda6e6720 error 4 in haproxy[400000+183000]
[14517156.564684] haproxy[1149]: segfault at 8 ip 000000000042ac55 sp 00007ffdb7ab6a20 error 4 in haproxy[400000+183000]
./haproxy -vvv
HA-Proxy version 1.9.1 2019/01/08 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -m64 -march=x86-64 -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_ZLIB=1 USE_CPU_AFFINITY=1 USE_OPENSSL=1 USE_PCRE=1 USE_TFO=1
Built with OpenSSL version : OpenSSL 1.0.1k-fips 8 Jan 2015
Running on OpenSSL version : OpenSSL 1.0.1k-fips 8 Jan 2015
Built with PCRE version : 8.21 2011-12-12
Running on PCRE version : 8.21 2011-12-12
h2 : mode=HTX side=FE|BE
h2 : mode=HTTP side=FE
: mode=TCP|HTTP side=FE|BE
Provide a backtrace as explained in post #2 please.
GNU gdb (GDB) Amazon Linux (7.6.1-64.33.amzn1)
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “x86_64-amazon-linux-gnu”.
For bug reporting instructions, please see:
http://www.gnu.org/software/gdb/bugs/…
Reading symbols from /tmp/haproxy…done.
[New LWP 32487]
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib64/libthread_db.so.1”.
Core was generated by `./haproxy -d -db -f /etc/haproxy/haproxy.cfg’.
Program terminated with signal 11, Segmentation fault.
#0 0x000000000055b90e in srv_add_to_idle_list (srv=0x1d12950, conn=0x3c7c660) at include/proto/server.h:244
244 LIST_ADDQ(&srv->idle_orphan_conns[tid], &conn->list);
(gdb) bt
#1 0x000000000055cdaf in session_free (sess=0x2d8a8e0) at src/session.c:90
#2 0x000000000055cea7 in conn_session_free (conn=0x2d8a730) at src/session.c:112
#3 0x0000000000579cfc in mux_pt_destroy (ctx=0x2d8a9b0) at src/mux_pt.c:38
#4 0x000000000057a0ff in mux_pt_detach (cs=0x2d8aa50) at src/mux_pt.c:193
#5 0x000000000045dab0 in cs_destroy (cs=0x2d8aa50) at include/proto/connection.h:708
#6 0x000000000045e2f3 in si_release_endpoint (si=0x2d8ad38) at include/proto/stream_interface.h:170
#7 0x000000000045fac2 in stream_free (s=0x2d8aaa0) at src/stream.c:446
#8 0x000000000046619d in process_stream (t=0x2d8ae90, context=0x2d8aaa0, state=1025) at src/stream.c:2610
#9 0x0000000000574d37 in process_runnable_tasks () at src/task.c:432
#10 0x00000000004b9cb8 in run_poll_loop () at src/haproxy.c:2619
#11 0x00000000004ba037 in run_thread_poll_loop (data=0x23f91b0) at src/haproxy.c:2684
#12 0x00000000004bb871 in main (argc=5, argv=0x7ffd28d76d58) at src/haproxy.c:3313
(gdb) bt full
No locals.
conn = 0x3c7c660
conn_back = 0x3c7c7b8
srv_list = 0x3c7c810
srv_list_back = 0x2d8a968
No locals.
conn = 0x2d8a730
conn = 0x2d8a730
ctx = 0x2d8a9b0
No locals.
conn = 0x0
cs = 0x2d8aa50
appctx = 0x0
sess = 0x2d8a8e0
fe = 0x1cc29b0
—Type to continue, or q to quit—
bref = 0x2d8abc8
back = 0x2d8abc8
cli_cs = 0x2d8aa50
must_free_sess = 0
i = 0
srv = 0x0
s = 0x2d8aaa0
sess = 0x2d8a8e0
rqf_last = 12640288
rpf_last = 2151719008
rq_prod_last = 9
rq_cons_last = 9
rp_cons_last = 9
rp_prod_last = 9
req_ana_back = 0
req = 0x2d8aab0
res = 0x2d8ab10
si_f = 0x2d8ad38
si_b = 0x2d8ad78
t = 0x2d8ae90
state = 1025
ctx = 0x2d8aaa0
process = 0x462977 <process_stream>
t = 0x3cac700
max_processed = 73
next = 951060494
exp = 951060049
ptif = 0x82fa40 <per_thread_init_list>
ptdf = 0x0
start_lock = 0
tids = 0x23f91b0
threads = 0x23f7170
i = 1
old_sig = {__val = {0, 140575788085425, 140724603453564, 140725288660312, 18446603344811131004, 2, 0, 0, 18446603348420891937, 2, 18446603348420891921, 2, 0, 0,
390842023984, 140725288659696}}
blocked_sig = {__val = {18446744067199990583, 18446744073709551615 <repeats 15 times>}}
err = 0
retry = 200
limit = {rlim_cur = 104445, rlim_max = 104445}
errmsg = “\000m\327(\375\177\000\000Xm\327(\375\177\000\000\005\000\000\000\000\000\000\000l\262\356Y\332\177\000\000[\001\000\000\000\000\000\000\030\000\000\000\000\000\000\000\315e\177Z\332\177\000\000\230\002oZ\332\177\000\000 \206\315Z\332\177\000\000@\221\312\001\230\001\000\000\362i\177Z\332\177\000\000\001\000\000\000\n\000\000\00—Type to continue, or q to quit—
0\210m\327(”
pidfd = -1
That’s a crash that was fixed after 1.9.1 was released.
If you want to manually apply the patch, is this one here:
https://www.mail-archive.com/haproxy@formilux.org/msg32331.html
A workaround is to set http-reuse to never.
Do you happen to use server templates ?
If so, it’s been fixed in master already, with commit http://git.haproxy.org/?p=haproxy.git;a=commit;h=43bb842a08a6b772f1d76ff481d5555a8c871dcd
Yes.
Ok, I’ll check it Tomorrow.
The latest master branch works fine for me.
