[SOLVED] HAProxy+Keepalived can't create a FTP session with Virtual IP
Hi all,
FTP doesn’t seem to work when I connect to the Virtual IP (VIP), but when I connect to the local IP of one of the two Proxy’s it works fine.
I see it wants to connect, but when the FTP data port comes up (PASV) it stops.
SFTP works fine without a problem so I think it’s something with the passive FTP ports that aren’t being routed correctly?
Log Filezilla:
Status: Resolving address of lb.example.com
Status: Connecting to 192.168.1.10:21…
Status: Connection established, waiting for welcome message…
Status: Server does not support non-ASCII characters.
Status: Logged in
Status: Retrieving directory listing…
Command: PWD
Response: 257 “/” is current directory.
Command: TYPE I
Response: 200 Type set to I.
Command: PASV
Error: Disconnected from server: ECONNABORTED - Connection aborted
Error: Failed to retrieve directory listing
Status: Disconnected from server
Status: Logged in
Command: PWD
Command: TYPE I
Command: PASV
My setup:
I have two HAProxy servers with Keepalived on them with a VIP.
Behind the two HAProxy servers are two FTP Servers.
Can anyone help me with finding and if possible solving the problem?
You normally need to do the following:
  1. In your FTP server software restrict the PASV port range to something smaller and more controllable.
  2. Include the PASV port range in your VIP
  3. Set the external IP address so the FTP server knows the address of the HAproxy VIP that clients will connect to.
We cover it in a Blog here: https://www.loadbalancer.org/blog/how-to-load-balance-microsoft-windows-ftp-server-with-haproxy/
Hi AaronWest,
Thank you for your reply.
I tried to add the VIP like you and the blog said, but when I restart the HAProxy server with the new config I get the following error in the HAProxy logging:
Starting proxy ftp-pool: cannot bind socket [192.168.1.10:22]
Before the VIP I used the wildcard * , but when the FTP client connects to the VIP the FTP data part seems to fail.
The reason why it can’t bind to that IP is because the VIP is on the other Proxy server (Proxy01). When it’s down Keepalived will bring the VIP to this Proxy (Proxy02), but HAProxy needs to be restarted at this point which defeats the purpose as this should be a hot-standby server.
The passive port range can’t be smaller then this because we have a lot of sessions coming in.
I’m confused about point 3 with the external IP address. Do I need to define this inside the FTP server?
Current HAProxy config is:
GLOBAL CONFIG
    ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RS$
DEFAULTS CONFIG
HAPROXY DASHBOARD CONFIG
bind 192.168.1.32:1936
    maxconn 100
    clitimeout      100s
    srvtimeout      100s
    contimeout      100s
    timeout queue   100s
    stats hide-version
    stats refresh 30s
    stats show-node
    stats auth admin:password
    stats uri  /haproxy?stats
POOL CONFIG
listen ftp-pool
bind 192.168.1.10:21 transparent
bind 192.168.1.10:50000-50049 transparent
maxconn 2000
option tcp-check
balance source
hash-type consistent
server ftp01 192.168.1.1 check port 21
server ftp02 192.168.1.2 check port 21
listen sftp-pool
bind 192.168.1.10:22
maxconn 2000
option tcp-check
balance source
server ftp01 192.168.1.1:22 check port 22
server ftp02 192.168.1.2:22 check port 22
The keepalived config:
global_defs {
notification_email {
system-engineering-department@example.com
notification_email_from haproxy02@example.com
smtp_server 192.168.1.50
smtp_connect_timeout 30
vrrp_instance VRRP1 {
state BACKUP
Specify the network interface to which the virtual address is assigned
interface ens160
virtual_router_id 41
Add smtp alert
smtp_alert
Set the value of priority lower on the backup server than on the master server
priority 100
advert_int 1
authentication {
    auth_type PASS
    auth_pass xxxxxxxx
virtual_ipaddress {
    192.168.1.10/24
That’s what the “transparent” declaration on the bind line does in the FTP VIP, it allows you to bind the process to an IP not currently on the box.
Ha! I just needed to at the transparent part to the SFTP pool too like you said and now HAProxy is running again. Thanks.
Unfortunately I’m still having the same issue with the FTP data connection. Am I missing something in the config?
Can I check that you did point 3 already?
That part was confusing for me. Where do i set this and do you mean the WAN IP?
We use Serv-U FTP server on Windows and can’t put the external IP address anywhere.
as per ServU KB 1044:
next step is to configure the IP address Serv-U uses for its response to the PASV command so that it uses the actual IP address and not the internal IP that Serv-U sees
  • Navigate to Domain Details | Listeners
  • Select your FTP/FTPS listener(s) and click Edit
  • Enter the external IP address
Hi Lukastribus,
Thanks! I already had put the external IP address there. To troubleshoot further I tried the DNS name which Serv-U also allows, but without success. The FTP sessions keeps stopping after the PASV command. This also happends when on the LAN so I tried enabling the “Use with LAN connections” option, but also without success.
screen07
You are trying from a different Internet connection, not the same Internet connection as the FTP server, right?
Please login via https://ftptest.net/ and share the complete output.
It seems I made a mistake with the Cisco Firewall.
I created the nat to the VIP, but forgot to add the VIP to the ACL list.
The ftptest.net website gave me enough info to figure this out.
Thank you both for helping out!
