I want to associate a set of backends with a user/tenant and load balance those backends by user/tenant.
I want the same user id to load balance to the same set of servers.
I am reading Haproxy sourcecode trying to work out where to put this functionality.
Say I have X tenants or users and Y servers. The users only exist on X/Y servers.
I suspect I can (a) download a user to server mapping list on startup. (B) introduce a header that the backend server replies with the set of servers to be used by that user once logged in.
I need to override the load balancing to only use servers that are mapped by a user id. A user stays on a particular set of servers
I could generate a very large configuration file but I was hoping there was a way I can do this dynamically. I could use Consul and consul template to template the user to server mappings for example.
timeout client 10s
timeout server 10s
timeout http-request 10s
frontend frontend
bind 127.0.0.1:80
default_backend serverfarm
backend serverfarm
sharding cookie SERVER shardserver:5006/users.json
cookie SERVER insert indirect nocache
server server1 server1:8000
server server2 server2:8000
server server3 server3:8000
server server4 server4:8000
server server5 server5:8000
server server6 server6:8000
server server7 server7:8000
server server8 server8:8000
server server9 server9:8000
frontend stats
bind *:8404
stats uri /stats
stats refresh 10s
stats admin if LOCALHOST
frontend frontend
bind *:7000
# inspect-delay was required or else was seeing timeouts during lua script run
# tcp-request inspect-delay 1m
# This line intercepts the incoming tcp request and pipes it through lua function, called "pick backend"
http-request lua.shard
# use_backend based off of the "streambackend" response variable we inject via lua script
use_backend %[var(req.shard)]
backend shard0
server 0_0 127.0.0.1:8000 check
server 0_1 127.0.0.1:8001 check
server 0_2 127.0.0.1:8002 check
backend shard1
server 1_0 127.0.0.1:8003 check
server 1_1 127.0.0.1:8004 check
server 1_2 127.0.0.1:8005 check
backend shard2
server 2_0 127.0.0.1:8006 check
server 2_1 127.0.0.1:8007 check
server 2_2 127.0.0.1:8008 check
backend shard3
server 3_0 127.0.0.1:8009 check
server 3_1 127.0.0.1:8010 check
server 3_2 127.0.0.1:8011 check
backend shard4
server 4_0 127.0.0.1:8012 check
server 4_1 127.0.0.1:8013 check
server 4_2 127.0.0.1:8014 check
backend shard5
server 5_0 127.0.0.1:8015 check
server 5_1 127.0.0.1:8016 check
server 5_2 127.0.0.1:8017 check
usershard.lua
local function shard(txn)
shard = 'shard0'
local logicalshard = "0"
local tcp = core.tcp()
local headers = txn.http:req_get_headers()
if headers then
local cookie = headers["cookie"]
if cookie then
session = cookie[0]
if session then
found_cookie = session:match("username=([a-zA-Z0-9]+)")
if found_cookie then
print("User has a shard cookie")
print(found_cookie)
logicalshard = string.gsub(found_cookie, "[^a-zA-Z0-9]+", "")
end
end
tcp:settimeout(1)
if tcp:connect("127.0.0.1", "5000") then
if tcp:send("GET /shards/" .. logicalshard .." HTTP/1.1\r\nconnection: close\r\n\r\n") then
while true do
local line, _ = tcp:receive('*l')
if not line then break end
if line == '' then break end
end
local line, _ = tcp:receive('*a')
shard = "shard" .. line
end
tcp:close()
else
print('Socket connection to shardserver failed')
end
print('Shard is', shard)
print(txn.http)
end
end
txn:set_var('req.shard', shard)
end
core.register_action('shard', {'http-req'}, shard)
