Im try to put Dns-over-TLS and HTTPS into HAproxy 1.9.7 on Debian9
This settings works with DoH, but DoT not working. I wanna share port 443 on both services
Without HTTP/2, everything works fine ~~
frontend doh-in
no log
bind :::443 v4v6 ssl crt /etc/haproxy/dot-jp.blahdns.pem alpn h2,http/1.1
http-response set-header Strict-Transport-Security "max-age=31536000"
tcp-request inspect-delay 3s
tcp-request content accept if HTTP
use_backend dot-server if { req.ssl_hello_type 1 }
use_backend doh-server if { ssl_fc_alpn -i h2 }
use_backend doh-server if HTTP
acl dns_url path /dns-query
use_backend doh-server if dns_url
default_backend dot-server
backend dot-server
server dns 127.0.0.1:50
backend doh-server
http-response del-header server
http-response del-header x-powered-by
server doh-proxy 127.0.0.1:3000
