We load balance LDAP / LDAPS connections (OpenLDAP 2.5.16) and have a mix for legacy reasons of LDAP 389 and much more used LDAPS 636 in our environment. These two protocols use separate frontend VIP’s and separate backends.
Because we do PROXY protocol for retaining the client IP, the port is 8636 and 8389 respectively for the backends. The frontends are essentially identical, just with port 389 and 636 respectively as bind ports.
backend be-ldap-test-8636-ro-PROXY from unnamed_defaults_1
option ldap-check
timeout server 300s
default-server inter 3s rise 2 fall 3 # alctl: default check parameters
server openldap-test-1 1.1.1.1:8636 maxconn 1000 weight 10 check send-proxy-v2
server openldap-test-2 1.1.1.2:8636 maxconn 1000 weight 10 check send-proxy-v2
server openldap-test-3 1.1.1.3:8636 maxconn 1000 weight 10 check send-proxy-v2
backend be-ldap-test-8389-PROXY from unnamed_defaults_1
option ldap-check
timeout server 300s # alctl: server inactivity timeout
server openldap-test-1 1.1.1.1:8389 maxconn 1000 weight 10 check send-proxy-v2
server openldap-test-2 1.1.1.2:8389 maxconn 1000 weight 10 check send-proxy-v2
server openldap-test-3 1.1.1.3:8389 maxconn 1000 weight 10 check send-proxy-v2
I noticed that the check “ldap-check” exists, which is wonderful, and I enabled it for the two backends. It works no issue for the backend on 389 LDAP, but always fails for the 636 backend.
The OpenLDAP server reports “TLS negotiation failure” and “closes” the connection during the check for LDAPS, and a success for normal LDAP on 8389.
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958503 fd=25 ACCEPT from IP=1.1.1.6:37536 (IP=1.1.1.6:8389)
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958503 op=0 BIND dn="" method=128
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958503 op=0 RESULT tag=97 err=0 qtime=0.000018 etime=0.000120 text=
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958503 fd=25 closed (connection lost)
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958504 fd=25 ACCEPT from IP=1.1.1.8:26648 (IP=1.1.1.6:8636)
Feb 17 15:36:09 openldap-test-1 slapd[1308]: conn=958504 fd=25 closed (TLS negotiation failure)
From what I can see, the option ldap-check has no further options to do SNI, or send a particular type of request. Can anyone help me with what might be going on ?
