I’m trying to use Google Distroless to tighten the security of my HAProxy container workload.
Almost everything is working. Meaning general SSL termination, redirects, acl’s and what not. The only thing that is giving me a headache is mutual-authentication when using the distroless approach. N.B. mutual-authentication works when not using distroless!
I enabled verbose logging and the “error”/result I get is:
SOME_WAN_IP:40472 [30/Aug/2020:20:54:11.213] mutual_auth_clientcert/1: SSL handshake failure
This is my setup
The dockerfile
FROM haproxy:2.2.2 as build
# Initial configuration
ARG HAPROXY_USER=haproxy
# - Permissions: run as non-root user
# - File copying: needed HAProxy files to /opt for distroless in-sourcing
RUN addgroup --gid 1024 ${HAPROXY_USER} && \
adduser --ingroup ${HAPROXY_USER} --system --shell /bin/bash ${HAPROXY_USER} && \
mkdir -p /opt/etc && \
cp -a --parents /usr/local/etc/haproxy /opt && \
cp -a --parents /usr/local/sbin/haproxy /opt && \
cp -a --parents /lib/x86_64-linux-gnu/libz.so.* /opt && \
cp -a --parents /lib/x86_64-linux-gnu/libdl.so.* /opt && \
cp -a --parents /lib/x86_64-linux-gnu/libpthread.so.* /opt && \
cp -a --parents /lib/x86_64-linux-gnu/libm.so.* /opt && \
cp -a --parents /lib/x86_64-linux-gnu/libc.so.* /opt && \
cp -a --parents /usr/lib/x86_64-linux-gnu/libcrypto.so.* /opt && \
cp -a --parents /usr/lib/x86_64-linux-gnu/liblua5.3.so.* /opt && \
cp -a --parents /usr/lib/x86_64-linux-gnu/libpcre2-8.so.* /opt && \
cp -a --parents /usr/lib/x86_64-linux-gnu/libpcre2-posix.so.* /opt && \
cp -a --parents /usr/lib/x86_64-linux-gnu/libssl.so.* /opt && \
cp -a --parents /etc/passwd /opt && \
cp -a --parents /etc/group /opt
# GO DISTROLESS #
FROM gcr.io/distroless/base-debian10
COPY --from=build /opt /
# Set the container to run as the just created user
USER ${HAPROXY_USER}
# Boot value. The -W and -db options are needed in order for HAProxy to work
# with the distroless image
# -W == indicates to the HAProxy process that it should run in `master-worker mode`
# -db == disables background mode
CMD ["haproxy", "-W", "-db", "-f", "/usr/local/etc/haproxy/haproxy.cfg"]
The HAProxy config
# CONFIG & OVERALL SETUP #
# Global log options
log stdout format raw local0 info
# HAProxy configuration security
maxconn 1024
# Stats
stats socket /haproxysocket/haproxy.sock mode 660 level admin
stats timeout 2m
# Encryption conf.
ssl-default-bind-options force-tlsv12 prefer-client-ciphers
ssl-default-bind-ciphers ECDH+AESGCM:ECDH+CHACHA20:ECDH+AES256:ECDH+AES128:!aNULL:!SHA1
ssl-default-server-options force-tlsv12
ssl-default-server-ciphers ECDH+AESGCM:ECDH+CHACHA20:ECDH+AES256:ECDH+AES128:!aNULL:!SHA1
stats refresh 10s
stats uri /haproxy?stats
stats auth user:pass
# FRONTENDS #
frontend http_front
# Endpoint rules #
# Other domains letsencrypt request and renew config
acl letsEncrypt path_beg /.well-known
# a.domain.com
acl a-domain hdr_dom(Host) -i a.domain.com
acl a-domain-path path_beg /test
http-request redirect code 301 location /test if !a-domain-path a-domain !letsEncrypt
# Add headers #
http-request set-header X-Forwarded-Proto http
# Set the backend to use for the various endpoints #
# Lighttpd, with HTTP
use_backend lighttpd_back if a-domain !letsEncrypt
# Default backend
default_backend fun-and-games
frontend port443_splitter
bind :443
# Layer 4 inspects to split requests to different backends,
# for further re-circulation to dedicated TLS frontends.
# In order to support mutual auth.
# ROUTING RULES #
use_backend recir_clientcertenabled if { req_ssl_sni -i a.domain.com }
default_backend recir_clientcertenabled
frontend mutual_auth_clientcert
# Bind & conf. for a.domain.com
bind abns@mutual-auth-clientcert accept-proxy ssl crt /usr/local/etc/haproxy/pems/ ca-file /usr/local/etc/haproxy/mutualauth/ca.crt verify required crl-file /usr/local/etc/haproxy/mutualauth/ca_crl.pem alpn h2,http/1.1
# Endpoint rules #
# a.domain.com
acl a-domain hdr(Host) -i a.domain.com
# Lighttpd backend, with HTTPS
frontend https_front
# Setup HTTPS, load certificate files & advertise support for both HTTP2 & 1
#bind *:443 ssl crt /usr/local/etc/haproxy/pems/ alpn h2,http/1.1
bind abns@https-front accept-proxy ssl crt /usr/local/etc/haproxy/pems/ alpn h2,http/1.1
# Endpoint rules #
<JUST IMAGINE THAT THERE IS SOMETHING HERE>
# Add headers #
# Default backend
# BACKENDS #
backend recir_default
# Re-direct/loopback to all frontends that is not using mutual authentication
server loopback-for-tls abns@https-front send-proxy-v2
# Used for a.domain.com
server loopback-for-tls abns@mutual-auth-clientcert send-proxy-v2
http-response set-header Strict-Transport-Security "max-age=63072000; includeSubDomains;"
compression algo gzip
compression type text/html text/plain text/css application/javascript
server localhost_lighttpd lighttpd-something:80 check
backend lighttpd_letsencrypt_back
server localhost_lighttpd 127.0.0.1:8888 check
server localhost_pihole 192.168.0.20:808 check
Versions
- HAProxy: 2.2.2
- Docker: Docker version 17.09.1-ce, build 0bbe3ac
- The base image used,
FROM haproxy:2.2.2 as build, in the dockerfile can be glansed here HAProxy 2.2.2 base image dockerfile. As it can be seen from that dockerfile HAProxy is built with OpenSSL.
Checked and tried
- The certificate is valid (mutual-auth works when I’m not using a distroless image)
- I ran
lddon the HAProxy binary and it looks like I’m good in regards to needed libraries - I tried running
straceon a working container HAProxy workload, with mutual-auth, I was not able to conclude anything really usefull - There are no errors at container image build time
- To me this is likely somethign I’m not including/copying into the distroless end result in the container image. I’m at fault on what that might be
- I tried my luck the HAProxy Slack channel. I got some initial help but I think this forum fits better for my issue and troubleshooting it. My thread is just slowly disappearing over on Slack.
My hope is that someone here on this forum is able and willing to be me in the right direction. What I’m missing to include in the end-result distroless image or potentially give some insight into how and what componets that are involved when a self-signed certificate is used for mutual-authentication in HAProxy
Thank you very much in advance. Any help is highly regarded
