hi folks,
can anyone point me at how to log a possible bug - it’s not clear to me how to do this?
For info and comment, the issue appears to be with a change made back in
2014/04/23 : 1.5-dev23
MEDIUM: config: relax use_backend check to make the condition optional
I haven’t checked the source code (wouldn’t know how to read it!) but from behaviour it appears that the above change is actually also hiding errors in conditions on use_backend. for example, we had an issue where someone making a change to config made a typo of the form:
use_backend x of acl_y
i.e. “of” in place of “if”. In pre 1.5 version this config is rejected at start up (‘use_backend’ requires either ‘if’ or ‘unless’ followed by a condition) but in 1.7.1 system starts, reports no error and routes all traffic to backend x. Seems that the check is a bit too relaxed! I would have thought if anything present where a condition would be, then it should be validated - i.e. only a blank rest of line should be construed as no condition
- Adrian
