Hi!
Our load balancers distributes pac files to clients. As the pac files are used in browser and if the server goes down then the client will still use the same server even though its marked as down by load balancer because the client is using the pac file from temp or some cache.
Is there a way that Load balancer will reset all connections for down server so that the client will contact the load balancer and then the load balancer will provide pac file from active servers?
