Hi, i installed Gravitee recently and this API manager use 3 part to work: portal, management-api and a gateway
Each part use a specific port and i need help to make my haproxy acl for each one.
My origin url is http://gravitee.mydomain.com to go on the portal part
Management-APi add /management to the end of my url and need 8083 port
Gateway add /api to the end of my url and need 8082 port
So i start to create some acls but nothing work good
For information my haproxy.conf contain lot’s of acl for all the compagny websites.
Thanks for your help
