Stick-table doesnt create entry using dns name but ip works
I am using haproxy to load balance some remote desktop servers and the stick-table works except when I am using the dns name for the farm. If I used the ip address for the load balancer it works fine. If I use the actual domain name of the load balancer it works fine. If I use dns name that refers to the farms then the connection will work but no entry in stick table.
10.75.1.60 is virtual ip address for load balancers (this works)
10.75.1.61 is load balancer 1 (this works)
farm2.domain.com doesnt work (ip to 10.75.1.60)
lb1.corp.domain.com (10.75.1.61) works
I am stumped !
