Webclusters, Haproxy to Nginx
Hello.
Can someone please help me maybe I didn’t configure correctly or HAproxy shouldn’t run on loopback address?
I am trying to build a 3 VMs web-cluster setup with http-to-https redirection and self-signed certificate so that the internet browser shows “trusted”.
HA proxy is used as load balancer (192.168.101.1).
Operating system —> centos 8
Virtualization software —> VirtualBox
I have prepared a NAT Network - 192.168.100.0/24 - added the following port forwarding rules:
127.0.0.1 port 800 —> 192.168.101.1 port 80
127.0.0.1 port 4430 —> 192.168.101.1 port 443
When I try to acces from a browser:
https://127.0.0.1:4430 - it round robins but in the address bar it shows the image attached.
The biggest problem is that I can’t reach the webservers through:
http://127.0.0.1:800 - it shows this:
haproxy.cfg configuration:
frontend httpsandhttps
bind *:443 ssl crt /etc/haproxy/web.pem
timeout client 60s
default_backend allservers
backend allservers
timeout server 100s
server web1 192.168.101.101:80
server web2 192.168.101.102:80
