Hi!
I have a unix socket created at /app.sock
and it expects XMLRPC commands and haproxy has READ/WRITE access to the socket.
Normally, with something like lighttpd you can make a config point to an scgi server @ a socket file.
Or with NGINX you can do something like scgi_pass unix:/app.sock
I was testing something like this, but with no luck:
frontend in
bind *:5000
default_backend rpc
backend rpc
use-fcgi-app cgi
server sock-file /app.sock proto fcgi
fcgi-app cgi # confused by this, why does it need docroots, etc? i just want to pass commands to xmlrpc
log-stderr global
option keep-conn
docroot /var/www/my-app
Is there any way to do this with HAProxy?
