Hi All,
i’m configuring a new haproxy as a smtp and http/s proxy.
As a backend server i have 2 Kerio Connect email server.
all works good, but i have a strange behaviour of haproxy: after receive an email on port 25, haproxy dead.
This is when i start haproxy:
haproxy 17758 0.0 0.1 35192 1600 ? Ss 15:54 0:00 /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -D -p /var/run/haproxy.pid
root 17808 0.0 0.0 10432 672 pts/0 S+ 15:54 0:00 grep --color=auto haproxy
This is after an email on port 25
root 17815 0.0 0.0 10432 672 pts/0 S+ 15:55 0:00 grep --color=auto haproxy
If i try to check the status with service haproxy status:
haproxy dead, but /var/run/haproxy.pid exists.
This is my haproxy conf
option log-health-checks
option allbackups
#option forwardfor except 127.0.0.0/8
timeout check 10s
maxconn 20000
frontend http
redirect location https://kerio.cloud.com
frontend https-in
bind *:443
default_backend https-in
backend https-in
option ssl-hello-chk
stick-table type ip size 10M expire 30m
stick on src
server node02 77.xxx.xxx.xxx:443 check cookie node02
server node01 77.xxx.xxx.xxx:443 check cookie node01
frontend smtp-in
bind 0.0.0.0:25
default_backend smtp_outbound
log-format {“type”:“haproxy”,“timestamp”:%Ts,“http_status”:%ST,“http_request”:"%ci",“bytes_read”:%B,“upstream_addr”:"%si",“backend_name”:"%b",“retries”:%rc,“bytes_uploaded”:%U,“upstream_response_time”:"%Tc",“session_duration”:"%Tt",“termination_state”:"%ts"}
backend smtp
option smtpchk HELO kerio.cloud.com
server node02 77.xxx.xxx.xxx:25555 check
server node01 77.xxx.xxx.xxx:25555 check
No error in haproxy.log or syslog.
Any idea ?
