A day before we have taken reload for haproxy and next day we noticed that old process still occupying 4GB memory
~~Trace logs: Top 4 memory occupied processes are :
root@ip-10-0-x-xx:~# ps ax -o rss,user,command | sort -nr | head -n 4
8799424 haproxy /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid -D -sf 630
4918408 haproxy /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid -D -sf 27615
86292 ganglia /usr/sbin/gmond --pid-file=/var/run/ganglia-monitor.pid
29628 syslog rsyslogd
root@ip-10-0-x-xx:~#ps -ef | grep ha
haproxy 630 1 19 Jul28 ? 5-11:40:10 /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid -D -sf 27615
haproxy 13810 1 19 Aug24 ? 03:51:22 /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid -D -sf 630
Note:
processid :630 is old one which have occupied approx 4GB of ram
processid :13810 is latest one which have occupied approx 8GB of ram
Then we have checked that old id still have some few connection established :
root@ip-10-0-x-xx:~# lsof -p 630| grep TCP |wc -l
104
Note: 104 here means one for incoming and one for outgoing (i.e backend node)
i.e
root@ip-10-0-x-xx:~# lsof -p 630 | grep -v “ap-xxxx-y.compute.internal:xxxx” |grep TCP |wc -l
52
Please help me understand even with very less number of these connection on old process why it has occupied hefty memory
Please help me in order to find out the rca
Please use a single thread, not 3 threads for one problem. Crossposting is not getting you help any sooner, it will just led to wrong advice for the wrong people.
Post the output of “haproxy -vv” and the configuration (especially important are timeout values).
ubuntu@ip-10-0-x-xx:~$ haproxy -vv
TARGET = linux2628
CPU = native
CC = gcc
CFLAGS = -O2 -march=native -g -fno-strict-aliasing
OPTIONS = DLMALLOC_SRC=…/malloc.c USE_OPENSSL=1 USE_STATIC_PCRE=1
Built without zlib support (USE_ZLIB not set)
Compression algorithms supported : identity
Built with OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Running on OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Built with PCRE version : 8.31 2012-07-06
ubuntu@ip-10-0-x-xx:~$ cat /etc/haproxy/haproxy.cfg
maxconn 500000
stats socket /var/run/haproxy.socket group ganglia mode 775 level operator
maxconn 500000
timeout connect 300000
timeout client 660000
timeout server 660000
frontend inbound
rate-limit sessions 5000
bind *:port1
bind *:port2
bind *:port3
bind *:443 ssl crt /etc/ssl-cert-path/new-x.y.z.crt.pem
default_backend bk_servers
backend bk_servers
balance listen
server namexyz 10.0.x.yz:port check weight 100 inter 5000
Don’t use DLMALLOC unless you know exactly what you are doing. I have not seen a DLMALLOC build in a long time, it won’t certainly resolve your problems magically.
Seems to me the connection don’t timeout, I guess they continue to generate traffic so they don’t timeout.
I suggest you tcpdump those connections to see what kind of traffic still runs through those old processes (pick some of the ports from the lsof output and make a tcpdump filter for it).
