If the HTTP check fails and the agent returns a feedback of “up 50%”, would HA Proxy mark that host as DOWN?
There was an incident where requests would continue to be routed to the host failed the HTTP health check and I’m wondering if it’s possible that the agent is returning “up XX%” which might mark it as UP instead of DOWN.
Here’s an example config:
backend apiservers
option httpchk GET /check
http-check expect status 200
server server1 192.168.50.3:80 check agent-check agent-inter 5s agent-addr 192.168.50.3 agent-port 5555
If the agent-check returns “up”, the server will be marked up overwriting health checks:
- The word “up” sets back the server’s operating state as UP if health checks
also report that the service is accessible.
https://cbonte.github.io/haproxy-dconv/1.6/configuration.html#5.2-agent-check
Thanks - I’ve removed the agent-check troubleshoot the issue.
It turns out that the only requests that are going to the server marked as DOWN are the ones that have the session id that is stored in the stick table with the matching server id. Does anyone know if requests that have a match in the stick table will continue to be routed to the server marked as DOWN? I was under the impression that it should only route to UP servers.
In my backend configuration, I have defined the server ID for each server.
Yes, use option redispatch to break persistence in this case.
Thanks @lukastribus !
Along with the stick table, I actually have both option persist and option redispatch. In this case, should it have redistributed the request in case of failure? It seems like if there’s a match in the stick table, it sends the request to a DOWN server and doesn’t redispatch.
If I remove option persist and have only option redispatch, then it works as I expected, which is to route requests only to healthy servers.
