100% CPU usage with HAproxy 2.0.31
I recently updated the version of haproxy from 2.0.25 to 2.0.31 to get rid of some vulnerability.
It seemed okay and nothing special after updating, but about one or two weeks later, one of haproxy process suddenly consumes almost 100% of cpu. this high cpu usage doesn`t stay at a specific cpu, it keeps moving to other cpu(got 48 core). and this status continues after i remove all the traffic.
I googled for a long time but got nowhere… so help me please (I want to solve this problem without version updating)
let me share some debugging information!
Current version information
HA-Proxy version 2.0.31-c8b1c15 2023/02/14 - https://haproxy.org/
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits -DMAX_SESS_STKCTR=20
  OPTIONS = USE_PCRE=1 USE_PCRE_JIT=1 USE_PTHREAD_PSHARED=1 USE_REGPARM=1 USE_STATIC_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_TFO=1 USE_SYSTEMD=1
Feature list : -51DEGREES +ACCEPT4 -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL +EPOLL -EVPORTS +FUTEX +GETADDRINFO -KQUEUE +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA -MY_ACCEPT4 -MY_EPOLL -MY_SPLICE +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL +PCRE -PCRE2 -PCRE2_JIT +PCRE_JIT +POLL +PRCTL -PRIVATE_CACHE +PTHREAD_PSHARED +REGPARM +RT -SLZ +STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -VSYSCALL -WURFL -ZLIB
Built with multi-threading support (MAX_THREADS=64, default=48).
Built with OpenSSL version : OpenSSL 1.1.1t  7 Feb 2023
Running on OpenSSL version : OpenSSL 1.1.1t  7 Feb 2023
Built without compression support (neither USE_ZLIB nor USE_SLZ are set).
Compression algorithms supported : identity("identity")
Built with PCRE version : 8.44 2020-02-12
Running on PCRE version : 8.44 2020-02-12
Available services : none
haproxy.cfg
    log             127.0.0.1    local2    notice
    pidfile         /var/run/haproxy.pid
    maxconn         500000
    tune.bufsize    16384
    user            haproxy
    group           haproxy
    unix-bind       prefix /var/run/    mode 660    user haproxy group haproxy
    spread-checks   5
    tune.ssl.cachesize          400000
    tune.ssl.lifetime           86000
    tune.ssl.maxrecord          2859
    tune.ssl.default-dh-param   2048
    ssl-default-bind-options    no-sslv3
    # cipher suites
    ssl-default-bind-ciphers    ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA
    # for tls1.3
    ssl-default-bind-ciphersuites   TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256
    nbproc          1
    nbthread        48
    # http/1 header case adjustment
    h1-case-adjust-file    /etc/haproxy/h1-case-adjust-list.txt
    # CPU
    cpu-map         1/all   0-
    stats socket        /var/run/haproxy.stat1  process 1       level admin     expose-fd listeners
    server-state-file   /etc/haproxy/server_state
    mode       http
    log        global
    maxconn    500000
    option     httplog
    option     dontlognull
    option     log-separate-errors
    option     log-health-checks
    option     forwardfor    except    127.0.0.1
    #option     http-server-close
    option     redispatch
    option     tcp-smart-accept
    option     tcp-smart-connect
    option     abortonclose
    option     splice-auto
    option     http-use-htx
    option     h1-case-adjust-bogus-client
    retries                    3
    timeout    http-request    15s
    timeout    queue           10s
    timeout    connect         3s
    timeout    client          100s
    timeout    server          100s
    timeout    check           1s
    timeout    http-keep-alive 5s
    load-server-state-from-file     global
frontend    HTTPS
    bind            *:443    ssl crt-list /etc/haproxy/ssl/cert-list.txt    tls-ticket-keys /etc/haproxy/ssl/tls-ticket.key     alpn h2,http/1.1    npn h2,http/1.1
    backlog     100000
    timeout     http-keep-alive 100s
    # HSTS
    # rspadd Strict-Transport-Security:\ max-age=31536000
    http-request    set-header  X-Forwarded-Proto   https    if    !{ hdr(X-Forwarded-Proto) -m found }
    http-request    set-header  X-Forwarded-Host    %[req.hdr(host)]
    http-request    deny        deny_status 403              if    !{ req.hdr(host),lower,map_beg(/etc/haproxy/DomainToAccept.map) -m found }
    http-request    deny        deny_status 403              if     { req.hdr(host),lower,map_beg(/etc/haproxy/DomainToAccept.map) -m str http } { hdr(X-Forwarded-Proto) -m str https }
    stick-table     type        string       len 2048    size 100k        expire 10m      store   http_req_rate(10s),bytes_out_rate(60s)
    http-request    track-sc0   path
    use_backend     CACHE_POOL                      if      { sc0_http_req_rate gt 10 } { req.hdr(host),lower,map_beg(/etc/haproxy/DomainToAccept.map) -m found }
    use_backend     CACHE_POOL_HASH
    capture request header Host len 64
    log-format "%ci:%cp [%t] %ft %b/%s %Th/%Ti/%TR/%Tw/%Tc/%Tr/%Tt %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs %{+Q}r %sslv %sslc %[ssl_fc_sni] %[ssl_fc_is_resumed] %[ssl_fc_alpn] %[ssl_fc_npn]"
listen Stats
    bind        *:8500    process 1
    stats       enable
    stats       realm      Haproxy\ Statistics
    stats       uri        /
    stats       auth       bluetiger:qorentks
    stats       admin      if      TRUE
    stats       refresh    60s
frontend    HTTP
    bind            *:80
    http-request    redirect scheme https code 301   if    { req.hdr(host),lower,map_beg(/etc/haproxy/DomainToAccept.map) -m str https }
    http-request    allow                                    if     { hdr(host) -i  stat.haproxy }
    use_backend     STAT                            if      { hdr(host) -i  stat.haproxy }
    use_backend     RR_POOL                      if      { sc0_http_req_rate gt 10 } { req.hdr(host),lower,map_beg(/etc/haproxy/DomainToAccept.map) -m found }
    use_backend     HASH_POOL
    log-format "%ci:%cp [%t] %ft %b/%s %Th/%Ti/%TR/%Tw/%Tc/%Tr/%Tt %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs %{+Q}r"
backend        STAT
    server     STAT              127.0.0.1:9090         weight 10      check inter 10s
backend        HASH_POOL
    balance         uri
    hash-type       consistent
    http-reuse      safe
    server    x.x.x.1    x.x.x.1:8080    weight 10    check inter 1s
    server    x.x.x.2    x.x.x.2:8080    weight 10    check inter 1s
    server    x.x.x.3    x.x.x.3:8080    weight 10    check inter 1s
backend    RR_POOL
    http-reuse    safe
strace -tt -p
strace -tt -p 169075
strace: Process 169075 attached
18:23:47.072216 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=687996000}) = 0
18:23:47.072558 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688039247}) = 0
18:23:47.072693 epoll_wait(5, [], 200, 172) = 0
18:23:47.245032 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688135477}) = 0
18:23:47.245225 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688169765}) = 0
18:23:47.245326 epoll_wait(5, [], 200, 10) = 0
18:23:47.255525 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688237475}) = 0
18:23:47.255663 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688268626}) = 0
18:23:47.255781 epoll_wait(5, [], 200, 149) = 0
18:23:47.405125 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688341412}) = 0
18:23:47.405264 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688370830}) = 0
18:23:47.405392 epoll_wait(5, 0x2327860, 200, 47) = -1 EINTR (Interrupted system call)
18:23:47.426563 --- SIGALRM {si_signo=SIGALRM, si_code=SI_TIMER, si_timerid=0x22, si_overrun=0, si_value={int=17, ptr=0x7f9200000011}} ---
18:23:47.426647 clock_gettime(0xffffffffffeb5bd6 /* CLOCK_??? */, {tv_sec=97365, tv_nsec=821814677}) = 0
18:23:47.426780 timer_settime(34, 0, {it_interval={tv_sec=0, tv_nsec=0}, it_value={tv_sec=1, tv_nsec=0}}, NULL) = 0
18:23:47.426885 rt_sigreturn({mask=[]}) = -1 EINTR (Interrupted system call)
18:23:47.426992 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688588561}) = 0
18:23:47.427063 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688605798}) = 0
18:23:47.427130 epoll_wait(5, [], 200, 26) = 0
18:23:47.453302 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688659565}) = 0
18:23:47.453403 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688685802}) = 0
18:23:47.453517 epoll_wait(5, [], 200, 16) = 0
18:23:47.469702 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688751286}) = 0
18:23:47.469876 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688791795}) = 0
18:23:47.469965 epoll_wait(5, [], 200, 19) = 0
18:23:47.489138 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688854976}) = 0
18:23:47.489260 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688885230}) = 0
18:23:47.489379 epoll_wait(5, [], 200, 10) = 0
18:23:47.499644 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=688995558}) = 0
18:23:47.499825 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689024501}) = 0
18:23:47.499951 epoll_wait(5, [], 200, 49) = 0
18:23:47.549145 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689095901}) = 0
18:23:47.549309 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689136616}) = 0
18:23:47.549408 epoll_wait(5, [], 200, 10) = 0
18:23:47.559589 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689201456}) = 0
18:23:47.559697 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689229570}) = 0
18:23:47.559829 epoll_wait(5, [], 200, 28) = 0
18:23:47.588054 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689307597}) = 0
18:23:47.588221 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689350627}) = 0
18:23:47.588338 epoll_wait(5, [], 200, 44) = 0
18:23:47.632618 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689425838}) = 0
18:23:47.632826 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689501817}) = 0
18:23:47.632928 epoll_wait(5, [], 200, 233) = 0
18:23:47.866397 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689584365}) = 0
18:23:47.866560 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689617080}) = 0
18:23:47.866687 epoll_wait(5, [], 200, 33) = 0
18:23:47.899940 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689692940}) = 0
18:23:47.900065 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689722038}) = 0
18:23:47.900235 epoll_wait(5, [], 200, 313) = 0
18:23:48.213693 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689800393}) = 0
18:23:48.213836 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689833393}) = 0
18:23:48.213936 epoll_wait(5, [], 200, 31) = 0
18:23:48.245131 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689907734}) = 0
18:23:48.245315 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=689943453}) = 0
18:23:48.245411 epoll_wait(5, [], 200, 9) = 0
18:23:48.254623 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690007500}) = 0
18:23:48.254779 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690047248}) = 0
18:23:48.254880 epoll_wait(5, [], 200, 22) = 0
18:23:48.277127 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690126175}) = 0
18:23:48.277282 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690152426}) = 0
18:23:48.277406 epoll_wait(5, [], 200, 4) = 0
18:23:48.281659 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690234663}) = 0
18:23:48.281802 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690265234}) = 0
18:23:48.281954 epoll_wait(5, [], 200, 123) = 0
18:23:48.405323 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690353301}) = 0
18:23:48.405492 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690387879}) = 0
18:23:48.405588 epoll_wait(5, [], 200, 21) = 0
18:23:48.426819 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690455145}) = 0
18:23:48.426930 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690485220}) = 0
18:23:48.427052 epoll_wait(5, 0x2327860, 200, 22) = -1 EINTR (Interrupted system call)
18:23:48.429306 --- SIGALRM {si_signo=SIGALRM, si_code=SI_TIMER, si_timerid=0x22, si_overrun=0, si_value={int=17, ptr=0x7f9200000011}} ---
18:23:48.429402 clock_gettime(0xffffffffffeb5bd6 /* CLOCK_??? */, {tv_sec=97366, tv_nsec=822187902}) = 0
18:23:48.429513 timer_settime(34, 0, {it_interval={tv_sec=0, tv_nsec=0}, it_value={tv_sec=1, tv_nsec=0}}, NULL) = 0
18:23:48.429607 rt_sigreturn({mask=[]}) = -1 EINTR (Interrupted system call)
18:23:48.429703 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690626300}) = 0
18:23:48.429788 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690643060}) = 0
18:23:48.429869 epoll_wait(5, [], 200, 19) = 0
18:23:48.449024 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690694174}) = 0
18:23:48.449119 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690727866}) = 0
18:23:48.449256 epoll_wait(5, [], 200, 39) = 0
18:23:48.488547 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690804985}) = 0
18:23:48.488708 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690838812}) = 0
18:23:48.488824 epoll_wait(5, [], 200, 28) = 0
18:23:48.517138 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690918906}) = 0
18:23:48.517303 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=690950767}) = 0
18:23:48.517427 epoll_wait(5, [], 200, 3) = 0
18:23:48.520689 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=691018793}) = 0
18:23:48.520822 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=691046710}) = 0
18:23:48.520954 epoll_wait(5, [], 200, 34) = 0
18:23:48.555260 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=691140734}) = 0
18:23:48.555413 clock_gettime(CLOCK_THREAD_CPUTIME_ID, {tv_sec=1023, tv_nsec=691174656}) = 0
18:23:48.555508 epoll_wait(5, ^Cstrace: Process 169075 detached
show fd
      4 : st=0x05(R:PrA W:pra) ev=0x00(heopi) [lc] cnext=-3 cprev=0 tmask=0x1 umask=0x0 owner=0x2006410 iocb=0x5bcd80(mworker_accept_wrapper)
      6 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x2 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
      8 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lC] cnext=-3 cprev=-2 tmask=0xffffffffffff umask=0x0 owner=0x200a0a0 iocb=0x5730e0(listener_accept) l.st=RDY fe=GLOBAL
     10 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lC] cnext=-3 cprev=-2 tmask=0xffffffffffff umask=0x0 owner=0x200c160 iocb=0x5730e0(listener_accept) l.st=RDY fe=HTTPS
     11 : st=0x05(R:PrA W:pra) ev=0x00(heopi) [lC] cnext=-3 cprev=0 tmask=0xffffffffffff umask=0x0 owner=0x2231290 iocb=0x5730e0(listener_accept) l.st=RDY fe=Stats
     12 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lC] cnext=-3 cprev=-2 tmask=0xffffffffffff umask=0x0 owner=0x2233670 iocb=0x5730e0(listener_accept) l.st=RDY fe=HTTP
     14 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x4 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     17 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x8 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     20 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x10 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     23 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x40 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     26 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x100 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     29 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x200 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     32 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x800 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     35 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x2000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     38 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x8000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     41 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x40000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     44 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x200000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     47 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x400000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     50 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x1000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     53 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x4000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     56 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x8000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     59 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x20000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     62 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x100000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     65 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x400000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     68 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x800000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     71 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x1000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     74 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x2000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     77 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x8000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     80 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x10000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     83 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x40000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     86 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x80000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     89 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x200000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     92 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x800000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     95 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x20 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
     98 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x80 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    101 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x400 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    104 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x1000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    107 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x4000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    110 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x10000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    113 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x20000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    116 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x100000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    119 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x800000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    122 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x2000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    125 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x40000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    128 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x80000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    131 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x200000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    134 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x4000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    137 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x100000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    140 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x400000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    143 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x1 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    145 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x80000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    148 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x10000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    151 : st=0x05(R:PrA W:pra) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x20000000000 umask=0x0 owner=0x597850 iocb=0x597850(poller_pipe_io_handler)
    154 : st=0x22(R:pRa W:pRa) ev=0x01(heopI) [lc] cnext=-3 cprev=-2 tmask=0x800 umask=0x0 owner=0x7f9214312750 iocb=0x587e90(conn_fd_handler) back=0 cflg=0x00241300 fe=GLOBAL mux=PASS ctx=0x7f91941afc70
    913 : st=0x22(R:pRa W:pRa) ev=0x1d(HEOpI) [lc] cnext=-3 cprev=-2 tmask=0x20000 umask=0x0 owner=0x7f916817e220 iocb=0x587e90(conn_fd_handler) back=0 cflg=0x80301300 fe=HTTP mux=H1 ctx=0x7f91f007ec50 h1c.flg=0x40 .sub=2 .ibuf=16@0x7f916823b390+0/16384 .obuf=0@(nil)+0/0 h1s=0x7f9228306710 h1s.flg=0x4010 .req.state=MSG_DONE .res.state=MSG_DATA .meth=GET status=200 .cs.flg=0x00004000 .cs.data=0x7f921c0354f8
    968 : st=0x22(R:pRa W:pRa) ev=0x01(heopI) [Lc] cnext=-3 cprev=-2 tmask=0x20000 umask=0x0 owner=0x7f91c4081a60 iocb=0x587e90(conn_fd_handler) back=1 cflg=0x00202b00 sv=CACHE_POOL_HASH/183.111.124.40 mux=H1 ctx=0x7f9168139f30 h1c.flg=0x0 .sub=0 .ibuf=0@(nil)+0/0 .obuf=0@(nil)+0/0 h1s=0x7f91a4019ab0 h1s.flg=0x4210 .req.state=MSG_DONE .res.state=MSG_DATA .meth=GET status=200 .cs.flg=0x00008000 .cs.data=0x7f921c035550
perf record 1
perf record -F 99 -p 169075 -a -- sleep 60
Warning:
PID/TID switch overriding SYSTEM
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.875 MB perf.data (12165 samples) ]
perf report --stdio
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 12K of event 'cycles:ppp'
# Event count (approx.): 209035839845
# Overhead  Command  Shared Object      Symbol
    34.82%  haproxy  haproxy            [.] process_runnable_tasks
    14.87%  haproxy  haproxy            [.] h1_rcv_buf
    11.74%  haproxy  haproxy            [.] si_cs_recv
     8.57%  haproxy  haproxy            [.] stream_int_notify
     4.78%  haproxy  haproxy            [.] si_cs_process
     4.57%  haproxy  haproxy            [.] h1_wake_stream_for_recv
     3.98%  haproxy  [kernel.kallsyms]  [k] sysret_check
     2.89%  haproxy  haproxy            [.] h1_io_cb
     2.77%  haproxy  haproxy            [.] h1_process
     1.73%  haproxy  haproxy            [.] __pool_put_to_cache
     1.33%  haproxy  haproxy            [.] si_cs_io_cb
     0.83%  haproxy  haproxy            [.] h1_refresh_timeout
     0.46%  haproxy  [vdso]             [.] __vdso_clock_gettime
     0.40%  haproxy  haproxy            [.] h1_subscribe
     0.35%  haproxy  [kernel.kallsyms]  [k] update_curr
     0.26%  haproxy  [kernel.kallsyms]  [k] sys_clock_gettime
     0.25%  haproxy  haproxy            [.] _do_poll
     0.24%  haproxy  [kernel.kallsyms]  [k] sys_epoll_wait
     0.23%  haproxy  [kernel.kallsyms]  [k] _raw_spin_lock_irqsave
     0.22%  haproxy  [kernel.kallsyms]  [k] copy_user_enhanced_fast_string
     0.21%  haproxy  [kernel.kallsyms]  [k] _raw_spin_unlock_irqrestore
     0.20%  haproxy  [kernel.kallsyms]  [k] native_sched_clock
please file a bug on github, likely a bug was introduced:
However you really should move to a LTS version with a EOL that matches your expection, please see the table at http://www.haproxy.org/
Thanks mate.
I will file this bug on github
