hey everyone!
Trying to do something that I think should be simple but for whatever reason won’t work… End result I want: an HTTP request for:
http://example.com/foo/bar.jpg
should result in a 302 to
http://acme.com/foo/bar.jpg
but I want the original HTTP request to maintain it’s connection to example.com. My problem is that I see this:
HTTP/1.1 302 Found
Cache-Control: no-cache
Content-length: 0
Connection: close
when I want to see this:
HTTP/1.1 302 Found
Content-length: 0
and then to see this in curl:
- Connection #0 to host localhost left intact
I’ve tried every combination of adding “option http-keep-alive” to the defaults, frontend and backend sections. The syntax I’m using, inside of a backend config, looks like this:
http-request redirection location http://acme.com/foo/bar.jpg
Is there any way to configure haproxy to not close the original connection to example.com after doing a redirect to acme.com?
Please provide the output of haproxy -vv.
This is most likely depends on the release.
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Built with PCRE version : 7.8 2008-09-05
That’s from my test system… I also see the same problem on 1.7.
Thanks!
AJ
figured it out, looks like this was fixed in 1.8:
http://git.haproxy.org/?p=haproxy-1.8.git;a=commit;h=19b1412e021451d4c7ac39750b556efaaf8639bf
We’ll try to upgrade and see if that fixes things.
