502 Bad Gateway with large http headers (SH--)
Hi!
We have a problem with sending large http headers through haproxy 3.0.7-1ppa1~noble.
The backend server is a Ubuntu 22.04 with a nginx 1.18.0-6ubuntu14.5.
Few weeks ago the website was directly delivered from nginx on the backend server without any problems. To be able to put a maintenance site in front of the nginx while installing OS patches/reboot, we installed a new VM with haproxy in front of the nginx.
But now we have problems with http requests with large headers.
First we started with haproxy version 2.8.5-1ubuntu3.2 from ubuntu 22.04 repo. With this version we got only connection reset and no entry/message in haproxy.log. After upgrade to haproxy version 3.0.7-1ppa1~noble, we got 502 Bad Gateway response from haproxy and log entires in haproxy.log. And also the large http request was reaching the backend server (nginx).
The config:
haproxy -vv
HAProxy version 3.0.7-1ppa1~noble 2024/12/14 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2029.
Known bugs: http://www.haproxy.org/bugs/bugs-3.0.7.html
Running on: Linux 6.8.0-51-generic #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec  5 13:09:44 UTC 2024 x86_64
  TARGET  = linux-glibc
  CC      = x86_64-linux-gnu-gcc
  CFLAGS  = -O2 -g -fwrapv -g -O2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -ffat-lto-objects -fstack-protector-strong -fstack-clash-protection -Wformat -Werror=format-security -fcf-protection -fdebug-prefix-map=/build/haproxy-kwUUeo/haproxy-3.0.7=/usr/src/haproxy-3.0.7-1ppa1~noble -Wdate-time -D_FORTIFY_SOURCE=3
  OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_OT=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_QUIC_OPENSSL_COMPAT=1
  DEBUG   =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC -OPENSSL_WOLFSSL +OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION +QUIC +QUIC_OPENSSL_COMPAT +RT +SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=4).
Built with OpenSSL version : OpenSSL 3.0.13 30 Jan 2024
Running on OpenSSL version : OpenSSL 3.0.13 30 Jan 2024
Built with Lua version : Lua 5.4.6
Built with OpenTracing support.
Built with PCRE2 version : 10.42 2022-12-11
Built with gcc compiler version 13.3.0
       quic : mode=HTTP  side=FE     mux=QUIC  flags=HTX|NO_UPG|FRAMED
	[BWLIM] bwlim-in
	[BWLIM] bwlim-out
	[FCGI] fcgi-app
	[  OT] opentracing
cat /etc/haproxy/haproxy.cfg
	log /dev/log	local0
#	log /dev/log	local1 notice
	log /dev/log	local1 debug
        tune.maxrewrite 8192
        tune.bufsize 65535
	log	global
	mode	http
	option	httplog
	option	dontlognull
        timeout client  50000
        timeout server  50000
       # haproxy statistic page
        stats auth XXXX:XXXX
        stats uri /haproxy?stats
        stats realm Strictly\ Private
	default-server check inter 2000 rise 2 fall 5
frontend site-xxx_at_fe
	bind 10.x.x.x:80
	bind 10.x.x.x:443 ssl crt /etc/haproxy/ssl/site-xxx.at.pem crt /etc/haproxy/ssl/ alpn h2,http/1.1
	# sorry page to return when worst case happens and also backup backend is down
	acl vhost_site-xxx.at			hdr(host) -i "stg1.site-xxx.at"
	acl MAIN_backend_down			nbsrv(site-xxx_at_be) eq 0
	# https://www.iops.tech/blog/haproxy-dynamic-maintenance-page-using-unix-socket/
	# empty regex rule; will be filled on maintenance
	acl maintenance					path -i -u 9699 -m reg
	acl typo3_backend path_beg /typo3/
	acl internal_ip src 10.0.0.0/8	# VPN
	# drop connections without vhost set
	http-request silent-drop		if !vhost_site-xxx.at
	http-request deny if typo3_backend !internal_ip
	# redirect to https
	redirect scheme https code 301		if !{ ssl_fc }
	use_backend maintenance_be		if MAIN_backend_down
	use_backend maintenance_be		if maintenance
        default_backend site-xxx_at_be
        # check with http OPTION request and ssl connect the /health urlpath
        option httpchk OPTIONS /health
	http-check connect ssl alpn h2
	http-check send meth HEAD uri /health ver HTTP/2 hdr Host stg1.site-xxx.at
	# add client IP header X-Forwarded-For
	default-server ssl verify none alpn h2,http/1.1
	# backend server
	server wstg1 10.x.x.x:443  check
	server wmain1 10.x.x.x:80 check
	# we do not want a 200 in case of maintenance
	http-after-response set-status 503
The large request with curl:
curl 'https://stg1.site-xxx.at/hotel/203106/?ddate=2025-01-08&rdate=2025-03-24&dur=7' -H 'User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8' -H 'Accept-Language: de-AT,en-US;q=0.7,en;q=0.3' -H 'Accept-Encoding: gzip, deflate, br, zstd' -H 'Referer: https://www.site-xxx.com/hotels/r/353/?term=dubai&ddate=2025-01-08&rdate=2025-03-24&dur=7' -H 'DNT: 1' -H 'Sec-GPC: 1' -H 'Connection: keep-alive' -H 'Cookie: _ga_R6NBEK0SEH=GS1.1.1736259320.1.1.1736259560.0.0.1145470110; _ga=GA1.1.1752673086.1736259320; FPID=FPID2.2.djMpER1CAak43qrG8QmGBVJjKCil%2F28HgrGbT7zM61M%3D.1736259320; FPLC=N%2FZGw2Uv1nv6DMmmCTadQwis3TjLfvMHuju6DgImTwPJNVJoXpBNYpLg1CdqPgc9wVE4d6NMxOv8VfnubOy9nsm4D50YsPWZC7sZbvPvKCoUl8xpDSmdPn3PB1Dmgw%3D%3D; FPAU=1.2.1126819039.1736259320; FPGSID=1.1736259320.1736259517.G-R6NBEK0SEH.4kWwjpsJzcf2uM63MSE5Jw; favorites_RESTPLATZBOERSE-COM=%7B%22count%22:0,%22iff%22:%5B%5D,%22hotels%22:%5B%7B%22IffCode%22:174923,%22Name%22:%22Dukes%20The%20Palm,%20a%20Royal%20Hideaway%20Hotel%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:237868,%22Name%22:%22Radisson%20Beach%20Resort%20Palm%20Jumeirah%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:109967,%22Name%22:%22Sofitel%20Dubai%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:218746,%22Name%22:%22Hotel%20Riu%20Dubai%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:236999,%22Name%22:%22Marriott%20Resort%20Palm%20Jumeirah,%20Dubai%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:187970,%22Name%22:%22Rixos%20Premium%20Dubai%20JBR%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:189028,%22Name%22:%22The%20Retreat%20Palm%20Dubai%20MGallery%20by%20Sofitel%22,%22Region%22:%22Dubai%22,%22Category%22:4.5%7D,%7B%22IffCode%22:230352,%22Name%22:%22Taj%20Exotica%20Resort%20&%20Spa,%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:202978,%22Name%22:%22Royal%20Central%20Hotel%20-%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:91560,%22Name%22:%22Two%20Seasons%20Hotel%20&%20Apartments%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:61957,%22Name%22:%22The%20Westin%20Dubai%20Mina%20Seyahi%20Beach%20Resort%20&%20Marina%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:66289,%22Name%22:%22Atlantis,%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:228534,%22Name%22:%22Centara%20Mirage%20Beach%20Resort%20Dubai%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:196322,%22Name%22:%22W%20Dubai%20-%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:237993,%22Name%22:%22voco%20Dubai%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:76300,%22Name%22:%22Anantara%20The%20Palm%20Dubai%20Resort%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:229446,%22Name%22:%22NH%20Collection%20Dubai%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:210437,%22Name%22:%22Andaz%20Dubai%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:191742,%22Name%22:%22Raffles%20The%20Palm%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:191,%22Name%22:%22Le%20Royal%20Meridien%20Beach%20Resort%20&%20Spa%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:75093,%22Name%22:%22Rose%20Rayhaan%20by%20Rotana%22,%22Region%22:%22Dubai%22,%22Category%22:4%7D,%7B%22IffCode%22:22159,%22Name%22:%22Hilton%20Dubai%20Jumeirah%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:61820,%22Name%22:%22Amwaj%20Rotana%20-%20Jumeirah%20Beach%20Residence%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:195,%22Name%22:%22Al%20Habtoor%20Grand%20Resort,%20Autograph%20Collection%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D,%7B%22IffCode%22:203106,%22Name%22:%22Canal%20Central%20Hotel%20%E2%80%93%20Business%20Bay%22,%22Region%22:%22Dubai%22,%22Category%22:5%7D%5D%7D; rpb_lastSeenHotels=[{%22id%22:%2275093%22%2C%22name%22:%22Rose%20Rayhaan%20by%20Rotana%22%2C%22region%22:%22Dubai%22%2C%22category%22:4%2C%22urlparams%22:%22ddate=2025-01-08&rdate=2025-03-24&dur=7%22}%2C{%22id%22:%22191%22%2C%22name%22:%22Le%20Royal%20Meridien%20Beach%20Resort%20&%20Spa%22%2C%22region%22:%22Dubai%22%2C%22category%22:5%2C%22urlparams%22:%22ddate=2025-01-08&rdate=2025-03-24&dur=7%22}%2C{%22id%22:%22218746%22%2C%22name%22:%22Hotel%20Riu%20Dubai%22%2C%22region%22:%22Dubai%22%2C%22category%22:4%2C%22urlparams%22:%22ddate=2025-01-08&rdate=2025-03-24&dur=7%22}]' -H 'Upgrade-Insecure-Requests: 1' -H 'Sec-Fetch-Dest: document' -H 'Sec-Fetch-Mode: navigate' -H 'Sec-Fetch-Site: same-origin' -H 'Sec-Fetch-User: ?1' -H 'Priority: u=0, i' -H 'TE: trailers'
<html><body><h1>502 Bad Gateway</h1>
The server returned an invalid or incomplete response.
</body></html>
haproxy.log:
2025-01-29T12:20:58.347887+01:00 wsprox1 haproxy[1552886]: 10.x.x.x:46762 [29/Jan/2025:12:20:58.343] site-xxx_at_fe~ site-xxx_at_be/wstg1 0/0/2/-1/3 502 208 - - SH-- 1/1/0/0/0 0/0 "GET https://stg1.site-xxx.at/hotel/203106/?ddate=2025-01-08&rdate=2025-03-24&dur=7 HTTP/2.0"
nginx-access.log:
10.x.x.x - - [29/Jan/2025:12:26:24 +0100] "-" 000 0 "https://www.site-xxx.com/hotels/r/353/?term=dubai&ddate=2025-01-08&rdate=2025-03-24&dur=7" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0" -
As written, the large requests are working on nginx direct without haproxy.
I was playing around with these parameters in the haproxy.cfg:
        tune.bufsize 65535
but without success.
Is there any other setting in haproxy which is missing to get these large http header running through haproxy?
br, Marco
We changed the haprxy backend config to speak http 1.1 instead of http2 to nginx backend.
With this workaround we have no problems with large headers.
It looks like haproxy is not working correct with http2 backend traffic.
