I have following configuration,
log 127.9.9.1 local0 #debug
stats socket /run/adminha.sock mode 600 level admin
timeout client 2m
timeout server 2m
frontend outwards-haproxy
bind *:443 ssl crt /pathgiven no-sslv3
stats uri /stats
stats uri /stats
stats hide-version
stats auth admin:1234
acl is_off url_beg /smoke1/
use_backend offapp if is_off
backend offapp
option redispatch 1
retries 2
cookie platform_extension_sessionid prefix nocache
server off1 host1:8443 check ssl verify none cookie s1
server off2 host2:8443 check ssl verify none cookie s2
I m getting 503 if one of backend server is stopped. Why it is not seamlessly transferring connection ?? even if i have 2 nodes
