Hi everyone,
I have some strange behavior. Everything is working except the request to “/api/auth/GetFirstAuthentication” leading to 504 Gateway Timeout.
The log says:
<134>Jul 4 15:43:29 haproxy[8]: 172.30.0.1:35538 [04/Jul/2022:15:42:59.142] pub1~ app1/pws-srv1 0/0/0/-1/30050 504 198 - - sHVN 1/1/0/0/0 0/0 "POST https://localhost/api/auth/GetFirstAuthentication HTTP/2.0"
In case you wonder why localhost, I am using haproxy docker container before pushing to live.
As I found here, it looks like the backend application does send some kind of malformed or incomplete headers.
The backend app is in fact behind an IIS which is reverse-proxying the requests for '/, /api, /...' to different ports of the backend app itself.
Any ideas how to troubleshoot or overcome this?
full haproxy.cfg
# HAProxy version 2.6.1-f6ca66d, released 2022/06/21
# config based on the example cfg
# set block wide defaults
# The global section deals with process-wide settings (security, resource usage)
# all file names are relative to the directory containing this config
# file by default
default-path config
# refuse to start if any warning is emitted at boot (keep configs clean)
zero-warning
# Security hardening: isolate and drop privileges
chroot /var/empty
# daemonize
pidfile /var/run/haproxy-svc1.pid
# do not keep old processes longer than that after a reload
hard-stop-after 5m
# The command-line-interface (CLI) used by the admin, by provisionning
# tools, and to transfer sockets during reloads
stats socket /var/run/haproxy-svc1.sock level admin mode 600 user haproxy expose-fd listeners
stats timeout 1h
# send logs to stderr for logging via the service manager
log stderr local0
#log stdout format raw local0
# intermediate security for SSL, from https://ssl-config.mozilla.org/
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
# default settings common to all HTTP proxies below
defaults http
timeout client 30s
timeout server 30s
timeout http-keep-alive 2m
timeout queue 15s
timeout tunnel 4h # for websocket
# provide a stats page on port 8181
frontend stats
bind :8181
# provide advanced stats (ssl, h2, ...)
stats uri /
stats show-modules
stats refresh 5s
# some users may want to protect the access to their stats and/or to
# enable admin mode on the page from local networks
# stats auth admin:mystats
# stats admin if { src 10.0.0.0/8 172.16.0.0/12 192.168.0.0/16 127.0.0.0/8 }
# First incoming public service. Supports HTTP/1.x and HTTP/2, using HSTS,
# redirects clear to TLS. Uses a dedicated host name for the stats page.
frontend pub1
bind :80 name clear
bind :443 name secure ssl crt /certs/localhost.pem alpn h2,http/1.1 # change certificate file name
option socket-stats # provide per-bind line stats
# set HSTS for one year after all responses
#http-after-response set-header Strict-Transport-Security "max-age=31536000" # only for production
# silently ignore connect probes and pre-connect without request
option http-ignore-probes
# pass client's IP address to the server and prevent against attempts
# to inject bad contents
http-request del-header x-forwarded-for
# enable HTTP compression of text contents
compression algo deflate gzip
compression type text/ application/javascript application/xhtml+xml image/x-icon
# enable HTTP caching of any cacheable content
http-request cache-use cache
http-response cache-store cache
# remove server headers for security hardening
http-response del-header (Server|X-info)
default_backend app1
# The cache instance used by the frontend (200MB, 10MB max object, 1 hour max)
# May be consulted using "show cache" on the CLI socket
cache cache
total-max-size 200 # RAM cache size in megabytes
max-object-size 10485760 # max cacheable object size in bytes
max-age 3600 # max cache duration in seconds
process-vary on # handle the Vary header (otherwise don't cache)
# First application
backend app1
# Algorithm:
# - roundrobin is usually better for short requests,
# - leastconn is better for mixed slow ones, and long transfers,
# - random is generally good when using multiple load balancers
# abort if the client clicks on stop.
option abortonclose
# insert a session cookie for user stickiness
cookie app1 insert indirect nocache
# check the servers' health using HTTP requests (change hostname)
option httpchk
http-check send meth GET uri / ver HTTP/1.1 hdr host lab.local
# do not overload the servers (100 concurrent conns max each)
server app-srv1 10.1.50.223:80 cookie app-srv1 maxconn 100 check inter 1s
Thanks in advance!
