About the Help! category
This category is for people seeking help with their HAProxy setups.
Everyone’s time is valuable, so when asking for help, please at least check other topics that might relate to your issue, and if it’s a configuration issue then also take a look at the configuration samples which are supposed to be well tested and which might work for your case.
Join an existing topic if you find a description of your problem, it may help others get a better picture of the issue. Conversely don’t hijack existing topics with unrelated questions, create new ones instead.
Once your issue is solved, please take the time to share your configuration in the configuration samples category. That will help others start with something working and well tested.
