I have setup working with client certificate authentication.
I would like to make setup to block particular user based on CN field in client certificate from accessing URL with regular expression.
I can block url with regular expression with acl:
acl restricted_page url_reg TEST
http-request deny if restricted_page
which works and prevents me to access URL with keyword TEST.
I tried to filter users with http-request set-header X-SSL-Client-CN %{+Q}[ssl_c_s_dn(cn)]
but can’t make it working
Basically I would like to achieve something like this:
if client certificate CN=user1 then block URLs with keyword TEST1
if client certificate CN=user2 then block URLs with keyword TEST2
Thank you in advance for any suggestions
Put both conditions into the ACL (after confirming they work individually).
ok I managed to make it working, I have problem with space in username.
CN=Firstname SecondName
It works with:
acl allow_user req.fhdr(X-SSL-Client-CN) -i -m str FirstName\ Lastname
but doesn;t work with:
acl allow_user req.fhdr(X-SSL-Client-CN) -i -m str -f /etc/haproxy/users
It seems “space” in CN is problem here as it works for CNs without space included.
Any suggestion?
Thank you
I assume you tried but escaping with the backslash and verbatim in the file?
yes, i’ve tried many combinations
Ok, lets back up for a moment.
Instead of setting a http header, and then matching it, why don’t you match the variable directly in the ACL?
acl allow_user %{+Q}[ssl_c_s_dn(cn)] -i -m str FirstName\ Lastname
http-request deny if restricted_page allow_user
unfortunately doesn’t work this way
" unknown fetch method ‘%{…_s_dn(cn,2)]’"
This topic came up in my blog recently, we used this with an external file containing who was allowed.
http-request deny if !{ ssl_c_s_dn(cn) -f /etc/haproxy/allowed_cn.txt }
Check out the comments section at the bottom: http://www.loadbalancer.org/blog/client-certificate-authentication-with-haproxy/
work but second acl doesn’t work in this line e.g.
http-request deny if !{ ssl_c_s_dn(cn) -f /etc/haproxy/allowed_cn.txt } second_acl
Finally made it working:
acl allow_users ssl_c_s_dn(cn,2) -i -f /etc/haproxy/users
acl restricted_page url_reg -f /etc/haproxy/keywords
http-request deny unless !restricted_page allow_users
It doesn’t work for some reason with:
http-request deny if restricted_page !allow_users
