Hi, I found a solution (set timeout tunnel) but still want to understand.
I have a the API of an lxd-server behind HAproxy 2.4, in TCP-Mode.
If push some large data from the Client to this server, the connection breaks.
Some test and I could confirm its always after the “timeout client”.
Setting “timeout tunnel” or increase the client timeout, and the data transfer works well.
The main part of my hyproxy.cfg (and its a playground system, so its not a “good” config
frontend fe_tcp_443
bind :::443 v4v6
acl sshtls req_ssl_sni -i ssh.07q.de
acl lxc req_ssl_sni -i lxc.test.07q.de lxd-test
use_backend lxc if lxc
acl ssh_payload req.payload(0,7) -m str "SSH-2.0"
tcp-request content accept if ssh_payload
acl ssl req.ssl_hello_type 1
use_backend ssh if ssh_payload
use_backend terminate_tls if sshtls
use_backend internal if ssl !sshtls !lxc
default_backend checkmkagent
backend internal
server fe ::1:8080 send-proxy-v2
server fe ::1:8081
backend lxc
server lxc 10.15.195.1:8443
backend ssh
server lh 10.15.195.1:22
server checkmk 10.15.195.1:6556
