Hi Guys,
I am looking for a HAProxy solution where we want to translate the incoming url to completely different url, I have gone through the documentation and implemented where backend is using server ip and port.
Kindly suggest if someone achieve this before?
Ask-
www.original.com/test --> www.wanaBeoriginal.co.in/umenhum
To rewrite the the Host part of the URL you need to rewrite the Host header. And for the path, use set-path. You can match it all against a acl in the form of base:
acl acl_original base -i www.original.com/test
http-request set-header Host www.wanaBeoriginal.co.in if acl_original
http-request set-path /umenhum if acl_original
Thanks @lukastribus, Let me try it.
Can you please confirm, These settings are going to be in frontend configuration, what about backend?
as per my understanding, I dont want anything in backend as my URLs are already being translated to new URL.
The problem is, I can not access my backend server via IP and PORT, Services only can be accessed via https url.
Kindly suggest.
https://cbonte.github.io/haproxy-dconv/2.1/configuration.html#4-http-request
You’re allowed to put “http-request” statements in backends and frontends.
Also, in my testing HAProxy is smart enough to handle multiple “http-request” redirects in frontend/backends. I’m doing HTTP to HTTPS redirects and adding WWW, works fine besides preserving headers.
They belong in the frontend. You don’t need anything else in the backend.
I don’t know what that means.
Can you please guide if below config is correct for below - ?
https://qa.dummy.com:6909/blog --> https://updated.qa.dummy.com/api/blog/v1
frontend 6909
bind *:6909
acl acl_original base -i https://qa.dummy.com:6909
http-request set-header Host https://updated.qa.dummy.com if acl_original
http-request set-path /api/blog/v1 if acl_original
No, you need to remove the https:// prefix from both the ACL and the Host header.
Thanks, weirdly Settings are intermittently working when using https://qa.dummy.com:6909/blog but working fine when using direct url which is https://updated.qa.dummy.com/api/blog/v1
Getting below error when hitting HAProxy URL - https://qa.dummy.com:6909/blog from SOAP UI -
Thu Mar 26 09:49:04 EDT 2020:ERROR:Exception in request: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
I don’t know what you are trying to achieve, I don’t have your full configuration.
But what you did share is that port 6906 is not a SSL (HTTPS) port, but plaintext HTTP, so I’m unsure how https against port 6909 is supposed to work.
This is my config and I want to do a URL translation to new URL as below -
# Global settings
# need to:
# by adding the '-r' option to the SYSLOGD_OPTIONS in
# /etc/sysconfig/syslog
# log 127.0.0.1 local2
log 127.0.0.1 local0
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
unique-id-format %{+X}o\ %ci:%cp_%fi:%fp_%Ts_%rt:%pid
unique-id-header X-Unique-ID
timeout http-request 50s
timeout queue 1m
timeout client 1m
timeout server 1m
#timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
# haproxy-monitoring
listen haproxy-monitoring
bind *:1936
stats hide-version
#http-request set-path /projects/%[var(req.rewrite_project)]%[path] if { var(req.rewrite_project) -m found }
stats uri /
stats auth user:haproxy
frontend 6909
bind *:6909
acl acl_original base -i qa.dummy.com:6909
http-request set-header Host updated.qa.dummy.com if acl_original
You are listening as HTTP on port 6909. That’s not HTTPS, you’d have to configure ssl and a certificate here. And where is the backend configuration?
I want to do only URL Translation so no backend configuration defined for it.
You mean you want to send a redirect then?
Then:
- install the SSL certificate and enable SSL on port 6909
- instead of set-header and set-path, use redirect
something like:
http-request redirect location https://updated.qa.dummy.com/api/blog/v1 if acl_original
HA-Proxy version 2.0.13 2020/02/13 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_LIBCRYPT=1 USE_CRYPT_H=1 USE_OPENSSL=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
My settings are like this now -
frontend 6909
bind *:6909 ssl crt /etc/ssl/private/qa.dummy.com.pem
but when hitting from SOAP UI, getting below error -
503 Service Unavailable
Though service is available.
My perm files contains -
Well the URL probabily isn’t https://qa.dummy.com:6909, so they ACL will not match.
Do you need to condition the redirect based on a specific URL or is that not actually required? If the latter is the case, then just remove the ACL condition and wholesale redirect to whatever destination you like.
Thanks so much lukastribus, It worked by disabling acl.
