Hello
I’m very new to haproxy and having to learn on the fly because there was an urgent need to switch from nginx to haproxy (because nginx wouldn’t allow Host to be changed based on upstream server).
With nginx, I had:
nginx (public) > nginx (internal) >[private network]> remote server1
> remote server2
And the basic config was:
server server1.example.net:443 max_fails=5 fail_timeout=1s;
server server2.example.net:443 max_fails=5 fail_timeout=1s backup;
When a visitor requested www.example.net and server1 went offline, the request would be served from server2 without any disruption nor any action required by the visitor. This would happen within a few seconds.
However, with haproxy, it seems to hang for 20 seconds and then the visitor has to reload the page. I’d like haproxy to function similarly and seamless switch over to a backup. Could you please advise?
With haproxy the setup is now:
nginx (public) > haproxy (internal) >[private network]> remote server1
> remote server2
Here is the config I’m testing:
timeout client 50s
timeout server 50s
timeout http-request 10s
timeout http-keep-alive 60s
timeout tunnel 50s
frontend group1
bind *:8080
stats uri /stats
stats refresh 10s
http-response set-header X-Server %s
default_backend nodes
backend group1
balance first
http-send-name-header Host
server server1.example.net server1.example.net:443 id 1 weight 1 ssl check verify none
server server2.example.net server2.example.net:443 id 2 backup weight 2 ssl check verify none
The remote servers are in different geographic regions but I haven’t seen connect times longer than 200ms.
