Backend connect latency spikes on backend queue
Hi, we’ve observed an increase in backend connect time on all backends under the same frontend as soon as one starts to queue.
Just wondering if this is an expected behaviour or our configuration would benefit from some meaningful tuning?
For this example, bck1 starts to queue up to 10k+ requests on traffic spikes which is not an issue here but we can see at the time that other backends like bck2 (no queue, same load as before) starts to have larger backend connect times which then has a repercussion of processing less traffic (waiting for requests). Latency can spike from nominal 10ms up to 3s…
Some examples of the current configuration:
We are using [HAProxy version 1.8.12-8a200c7, released 2018/06/27]. Running on 1 process and thread.
pid = 14332 (process #1, nbproc = 1, nbthread = 1)
system limits: memmax = unlimited; ulimit-n = 200039
maxsock = 200039; maxconn = 100000; maxpipes = 0
Total number of connections established are way under the set limits (25k/req at max) and queue gets to (10-15k)
timeout client 10s
timeout server 1800s
timeout queue 60s
timeout check 1s
no option forceclose
no option tcp-smart-accept
option http-no-delay
log 127.0.0.1 len 5120 local0
frontend api
bind :80
bind :443 ssl crt ./
maxconn 100000
option http-buffer-request
backend bck1
fullconn 30000
option httpchk HEAD /rmi/status
http-check disable-on-404
server : check slowstart 20s maxconn 20
backend bck2
fullconn 30000
server : check slowstart 20s maxconn 500
Example of metrics from stress tests (no such huge spike as on production traffic but notable)
CPU busy is 100% on queue load on the haproxy servers itself and memory load jumps by ~400MB but there is still room to spare on the instances. Do note, CPU usage on production did not get above 30% on any node
Here are the metrics from the production traffic where you can clearly see in red when the queuing occurs, backend connect latency spikes on all backends. So is this an expected behavior or we can further tune the configuration to try and mitigate this? All of this traffic is http/https, haproxies are behind keepalived instances running least connection algorithm. Haven’t seen any difference using round-robin algo.
Thanks and any help appreciated!
EDIT:
adding verbose version output (all are haproxies are built on the same hardware with same build flags)
HA-Proxy version 1.8.12-8a200c7 2018/06/27
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -fno-strict-overflow -Wno-unused-label
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_SYSTEMD=1 USE_PCRE=1
Provide haproxy logs. This will make it clearer where the latency is spend.
Here is the log file (6mb compressed, 148mb uncompressed) https://filebin.net/bguucs8wftnlb4dp/haproxy.log.tar.bz2?t=mnklfo8v
that matches this Grafana graph on the time of the larger queue and latency spike
Once more, here is the redacted configuration with the used options:
Note - we use option http-buffer-request since slow loris attack was were easy to reproduce and this helps avoid it. Thank you and if anyone has some other idea, shoot!
    stats socket /var/run/haproxy_socket level admin
    server-state-file /var/lib/haproxy/haproxy_server_state
    chroot /var/empty/haproxy
    maxconn 100000
    ca-base /etc/ssl
    crt-base /etc/ssl
    tune.ssl.cachesize 1000000
    tune.http.logurilen 5120
    timeout client 10s
    timeout queue 60s
    timeout check 1s
    log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %TR/%Tw/%Tc/%Tr/%Ta\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %hs\ %{+Q}r\ %sslv\ %sslc
    default-server init-addr libc,last,none
  resolvers dns
    nameserver dns_balancer_dc1 X.X.X.X:53
    nameserver dns_balancer_dc2 X.X.X.X:53
    resolve_retries 3
    hold valid 10s
  frontend API
    bind X.X.X.X:80
    bind X.X.X.X:443
    maxconn 100000
    tcp-request connection track-sc1 src table haproxy-client-metrics
    acl ....
    use_backend ...
  backend backend-1
    fullconn 30000
    server ....
  backend backend-2
    fullconn 30000
    server ....
  backend backend-3
    fullconn 30000
    server ....
  backend backend-4
    fullconn 30000
    server ....
  backend haproxy-client-metrics
    stick-table type ip size 1m expire 30s store conn_cur,conn_rate(5s),http_req_rate(5s),http_err_rate(5s),bytes_in_rate(30s)
Both the log and the config are so heavily anonymized that I have no chance of understanding how they relate to each other.
If haproxy saturates an entire CPU core, which I believe you are saying, then the connect time will definitely go up, as haproxy cannot handle the events in time.
With the informations provided I can give some generic advise. Don’t use option http-no-delay, don’t use option http-buffer-request and upgrade to latest 1.8 stable, as there are over 200 known bugs in 1.8.12.
