I have found 2 differents ways to manage a unique ID header.
Firts one, with manually storing the value of uuid() in a transaction variable and adding in the request headers, then adding it back to the response if not already returned by the origin server :
frontend foo
acl xid_req_exists req.hdr(x-request-id) -m found
acl xid_res_exists res.hdr(x-request-id) -m found
http-request set-var(txn.xid) uuid()
http-request set-header x-request-id %[var(txn.xid)] unless xid_req_exists
http-after-response add-header x-request-id %[var(txn.xid)] unless xid_res_exists
Second one, with unique-id-format and unique-id-header :
frontend foo
unique-id-format %{+X}o\ %ci:%cp_%fi:%fp_%Ts_%rt:%pid
unique-id-header x-request-id
http-request set-header x-request-id %[unique-id] unless xid_req_exists
http-response set-header x-request-id %[unique-id] unless xid_res_exists
I’m wondering which way is the preferred one, and why.
On a different but related topic, I want to have the unique ID in HAProxy logs.
Should I use a “capture” (to put it automatically in the {} section), or change the log format to add a specific field ?
