I’m hoping someone can help me figure this out.
I used to have HAProxy set up such that requests on port 80 would redirect to SSL over port 443, and also explicit requests to SSL over port 8443 would also work. Then my CIO decreed that we were moving to using Let’s Encrypt for our SSL certs. I got that working on my HAProxy server, but now there’s no response when I try to go directly to port 8443.
Here’s my complete HAProxy.cfg file:
daemonDefault SSL material locations
crt-base /etc/ssl/privateDefault ciphers to use on SSL-enabled listening sockets.
For more information, see ciphers(1SSL). This list is from:
https://hynek.me/articles/hardening-your-web-servers-ssl-ciphers/
ssl-default-bind-ciphers TLS+ECDHE+RSA+WITH+AES+256+GCM+SHA384:TLS+ECDHE+ECDSA+WITH+AES+256+GCM+SHA384:TLS+ECDH+RSA+WITH+AES+256+GCM+SHA384:TLS+ECDH+ECDSA+WITH+AES+256+GCM+SHA384:TLS+ECDHE+RSA+WITH+AES+128+GCM+SHA256:TLS+ECDHE+ECDSA+WITH+AES+128+GCM+SHA256:TLS+ECDH+RSA+WITH+AES+128+GCM+SHA256:TLS+ECDH+ECDSA+WITH+AES+128+GCM+SHA256:TLS+ECDHE+RSA+WITH+AES+256+CBC+SHA384:TLS+ECDHE+ECDSA+WITH+AES+256+CBC+SHA384:TLS+ECDHE+RSA+WITH+AES+256+CBC+SHA:TLS+ECDHE+ECDSA+WITH+AES+256+CBC+SHA:TLS+ECDH+RSA+WITH+AES+256+CBC+SHA384:TLS+ECDH+ECDSA+WITH+AES+256+CBC+SHA384:TLS+ECDH+RSA+WITH+AES+256+CBC+SHA:TLS+ECDH+ECDSA+WITH+AES+256+CBC+SHA:TLS+ECDHE+RSA+WITH+AES+128+CBC+SHA256:TLS+ECDHE+ECDSA+WITH+AES+128+CBC+SHA256:TLS+ECDHE+RSA+WITH+AES+128+CBC+SHA:TLS+ECDHE+ECDSA+WITH+AES+128+CBC+SHA:TLS+ECDH+RSA+WITH+AES+128+CBC+SHA256:TLS+ECDH+ECDSA+WITH+AES+128+CBC+SHA256:TLS+ECDH+RSA+WITH+AES+128+CBC+SHA:TLS+ECDH+ECDSA+WITH+AES+128+CBC+SHA:HIGH:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS
ssl-default-bind-options no-sslv3 no-tlsv10Maximum allowed simultaneous connections
maxconn 2048Crypto key size
tune.ssl.default-dh-param 4096defaults
errorfile 504 /etc/haproxy/errors/504.httpFrontend definitions
frontend www-http
default_backend tomcatsfrontend www-https-443 bind *:443 ssl crt /etc/haproxy/certs/server.mycompany.com.pem acl secure dst_port eq 443 http-request replace-header Host ^(.*?)(:[0-9]+)?$ \1:443 reqadd X-Forwarded-Proto:\ https rspadd Strict-Transport-Security:\ max-age=31536000;\ includeSubDomains;\ preload rsprep ^Set-Cookie:\ (.*) Set-Cookie:\ \1;\ Secure if secure acl letsencrypt-acl path_beg /.well-known/acme-challenge/ use_backend letsencrypt-backend if letsencrypt-acl default_backend tomcats frontend www-https-8443 bind *:8443 ssl crt /etc/haproxy/certs/server.mycompany.com.pem acl secure dst_port eq 8443 http-request replace-header Host ^(.*?)(:[0-9]+)?$ \1:8443 reqadd X-Forwarded-Proto:\ https rspadd Strict-Transport-Security:\ max-age=31536000;\ includeSubDomains;\ preload rsprep ^Set-Cookie:\ (.*) Set-Cookie:\ \1;\ Secure if secure acl letsencrypt-acl path_beg /.well-known/acme-challenge/ use_backend letsencrypt-backend if letsencrypt-acl default_backend tomcatsBackend definitions
backend tomcats
http-request redirect scheme https if !{ ssl_fc }
server webapp1 xxx.xxx.xxx.xxx:8080 check cookie webapp1
server webapp2 yyy.yyy.yyy.yyy:8080 check cookie webapp2backend letsencrypt-backend server letsencrypt 127.0.0.1:54321
Interestingly, I see no trace of any attempts at communication on port 8443 in my haproxy.log file. I’ll attach that in a reply message if needed.
