Binding TCP port ranges to backend port ranges
Hi, I’d like to bind multiple internet TCP ports to multiple TCP ports internally. can that be achieved in a single frontend and backend pair?
Something like this:
frontend tcp12300_12399
  bind *:12300-12399 ssl crt /usr/local/etc/certs/
  default_backend tcp_backend_12300_12399
  server tcpserver tcp-server:12300-12399
I’d like to have traffic on port 12300 to go to port 12300 on tcp-server and 12301 to 12301 on tcp-server and so on until port 12399.
thanks for any help in advance!
Yes, you just DON’T specify any destination ports specification in the backend configuration.
Specify check port XX for the port used in health-checks, if you are doing health checking.
thanks a lot. i really appreciate it.
