Block IP address block ....deny ip is not working for some reason
frontend sites_com
bind xxx.xxx.xxx.xxx:80
bind xxx.xxx.xxx.xxx.xxx:443 ssl crt /etc/haproxy/ssl/
http-request deny if { src 114.119.150.101 }
# Add CORS headers when Origin header is present
capture request header origin len 128
# if a preflight request is made, use CORS preflight backend
http-request use-service lua.cors-response if METH_OPTIONS { capture.req.hdr(0) -m found }
# add Access-Control-Allow-Origin HTTP header to response if origin matches the list of allowed URLs
http-request set-header Access-Control-Allow-Origin %[capture.req.hdr(0)] if { capture.req.hdr(0) -m found }
    acl is-blocked-ip src 114.119.0.0/16
    http-request deny if is-blocked-ip
    tcp-request content reject if is-blocked-ip
This is currently in my production haproxy configuration however I am still getting traffic passed from 114.114.0.0 addresses. We are getting tons of traffic and I cannot figure out why my blacklist rule nor my broken out rules are stopping the traffic.
Any assistance is appreciated and I have scanned the internet and tried ever combination (including moving the rules with the configuration file) that I can find.
The ip address does not fall within that block, so the rule does not apply.
turns out the subnet needed to be /16 instead of /17 and this addressed the issue
