Building Containers stops HAProxy to redirect correctly
Hi!!! :smiley:
It’s the first time writing onto this site.
I have an Openshift istance, and 2 namespaces:
First-layer
Second-layer
the “default” namespace is occupied by HAProxy.
I have configured HAProxy to balance and backup these two Flask Images i deployed over the first and second layer namespaces.
haproxy config file:
log stdout format raw local0
maxconn 1024
timeout client 20s
timeout connect 20s
timeout server 10s
frontend fe_main
bind *:3000
default_backend be_main
backend be_main
server web1 flaskapp-flaskapp-chart.first-layer:8000 check resolvers dnsresolvers
server web2 flaskapp-flaskapp-chart.second-layer:8000 check backup resolvers dnsresolvers
nameserver dns1 dns-default.openshift-dns:53
nameserver dns2 10.217.4.10:53
resolve_retries 3
timeout retry 1s
hold nx 10s
hold valid 10s
resolve_retries 3
timeout resolve 1s
hold other 10s
hold refused 5s
This actually works very good with my structure!
But when i try to destroy and rebuild my pods HAProxy can’t take me to the Flask Application anymore…
I need to restart HAProxy pod and everything goes well. :slight_smile:
Is there something i forgot to use in the config file?
How can i make it find the new pod without having to restart the HAProxy Service?
Thanks!!! :smiley:
The likely cause is the server names. flaskapp-flaskapp-chart.first-layer only works at startup, because the system resolver appends the search domains from /etc/resolv.conf. Your resolvers section re-resolves at runtime, and HAProxy’s built-in resolver doesn’t use search domains. It queries the literal short name, gets NXDOMAIN, and never picks up the new IP after you rebuild. That’s why a restart fixes it. You can also go fully dynamic and skip startup resolution entirely with init-addr none on the server or default-server lines:
    default-server init-addr none
The servers start in maintenance and come up as soon as the resolvers section gets an answer, so the same resolver handles both startup and rebuilds.
Note: if you want to retain libc startup resolution, only if DNS fails haproxy will also start and use dynamic resolution: init-addr libc,none
