we cannot submit any text which contains "select " followed later by " into ". (Spaces are important). Presumably, it’s a rule somewhere to block SQL injection attacks. In this case, we want to submit this sentence: “I work with select partners and country representatives to create annual humanitarian response plans that compliment Muslim Aids strategic goals, but also take into consideration country-specific contexts and growth of partners.”
The simplest curl examples of working and failing requests:
Working OK - returns HTTP 302 redirect:
LAPTOP:~$ curl -i 'https://example.com/app/survey/response.jsp' -H 'Content-Type: application/x-www-form-urlencoded' --data-raw 'foo=I work with selectXXXXX partners and country representatives to create annual humanitarian response plans that compliment Muslim Aids strategic goals, but also take into consideration country specific contexts and growth of partners.'
HTTP/1.1 302
Set-Cookie: _TC_AUTHCOOKIE_JSESSIONID=7fca47c3-61a5-4555-85eb-9231a6af28a6; Path=/app/; Secure; HttpOnly; Secure
Set-Cookie: JSESSIONID=s6~E96F17364E9DC315FCF570AA04F06EB0; Path=/app/; HttpOnly; Secure
Pragma: no-cache
Cache-Control: no-store, no-cache, must-revalidate
Expires: Sat, 1 Jan 2000 12:00:00 GMT
P3P: CP='NON CUR OUR'
Content-Type: text/html;charset=UTF-8
Content-Length: 0
Date: Fri, 18 Mar 2022 12:57:45 GMT
FAILS - returns HTTP 504 Bad Gateway:
LAPTOP:~$ curl -i 'https://example.com/app/survey/response.jsp' -H 'Content-Type: application/x-www-form-urlencoded' --data-raw 'foo=I work with select partners and country representatives to create annual humanitarian response plans that compliment Muslim Aids strategic goals, but also take into consideration country specific contexts and growth of partners.'
HTTP/1.0 504 Gateway Time-out
Cache-Control: no-cache
Connection: close
<html><body><h1>504 Gateway Time-out</h1>
The server didn't respond in time.
</body></html>
There are no SQL injection rules in haproxy.cfg
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!DES-CBC3-SHA
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
bind 10.99.99.19:8088
stats refresh 5s
balance
timeout client 5000
timeout connect 4000
timeout server 30000
frontend http-example_prd
acl host_strict hdr(host) -i attract.example.com
acl host_strict hdr(host) -i api.example.com
redirect scheme https if !{ ssl_fc } host_strict
use_backend honeypots_http if { src -f /etc/haproxy/blacklist.acl }
default_backend example_prd_appserver_cluster_http_only
frontend https-example_prd
rspirep ^(set-cookie:.*) \1;\ Secure
bind *:443 ssl crt /etc/ssl/certs/star_example_com.pem crt /etc/ssl/certs/starr_surveys_com.pem no-sslv3 no-tlsv10 no-tlsv11
acl host_attract hdr(host) -i attract.example.com
acl host_api hdr(host) -i api.example.com
use_backend honeypots_https if { src -f /etc/haproxy/blacklist.acl }
use_backend example_prd_appserver_cluster if host_attract
use_backend example_prd_appserver_cluster if host_api
default_backend example_prd_appserver_cluster_otherd
option httpchk HEAD /v1/heartbeat HTTP/1.1\r\nHost:\ example.com
http-check expect status 200
server appserver1 10.11.11.14:80 check cookie s1 fall 1 rise 1 inter 10s
server appserver2 10.11.11.15:80 check cookie s2 fall 1 rise 1 inter 10s
server appserver3 10.11.11.16:80 check cookie s3 fall 1 rise 1 inter 10s
option httpchk HEAD /appserver/watchdog.html HTTP/1.1\r\nHost:\ example.com
server appserver4 10.12.12.21:9443 check cookie s4 fall 1 rise 1 inter 10s
server appserver5 10.12.12.22:9443 check cookie s5 fall 1 rise 1 inter 10s
server appserver6 10.12.12.23:9443 check cookie s6 fall 1 rise 1 inter 10s
server appserver4 10.12.12.21:8080 check cookie s7 fall 1 rise 1 inter 10s
server appserver5 10.12.12.22:8080 check cookie s8 fall 1 rise 1 inter 10s
server appserver6 10.12.12.23:8080 check cookie s9 fall 1 rise 1 inter 10s
server appserver7 10.13.13.39:443 check cookie s10 fall 1 rise 1 inter 10s ssl verify none
server appserver8 10.13.13.31:443 check cookie s11 fall 1 rise 1 inter 10s ssl verify none
server appserver7 10.13.13.39:80 check cookie s12 fall 1 rise 1 inter 10s
server appserver8 10.13.13.31:80 check cookie s13 fall 1 rise 1 inter 10s
Please help or suggest what can be a problem in this case.
Thank you.
