I’m trying to proxy wss websocket connection from HAproxy to wss://demo.piesocket.com/v3/channel_1?api_key=oCdCMcMPQpbvNjUIzqtvF1d2X2okWpDQj4AwARJuAgtjhzKxVEjQU6IdCjwm¬ify_self, but seems failing to achieve it due to “ssl handshake failure” error. I’m using self signed certificate.
In haproxy logs I can see errors:
How I can resolve this and simply proxy Websockets on HTTPS from the root. (e.g. wss:///) to wss mentioned above?
Here is my code:
# ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
# ssl-default-bind-options no-sslv3
frontend haproxy
# bind *:443 ssl crt /etc/ssl/private/mydomain.pem
bind *:443 ssl crt /etc/ssl/private/test.pem
monitor-uri /healthcheck
monitor fail if { nbsrv(tomcat) eq 0 }
acl is_root path -i /
redirect location /hello/ImageServlet if is_root
default_backend tomcat
acl is_websocket hdr(Upgrade) -i WebSocket
acl is_websocket hdr_beg(Host) -i wss
use_backend websocket if is_websocket
backend tomcat
option httpchk GET /hello/ImageServlet
server node1 172.20.135.79:8080 check
server node2 172.20.136.121:8080 check
backend websocket
balance source
option forceclose
option tcp-check
# option ssl-hello-chk
# http-request add-header X-Forwarded-Proto https if { ssl_fc }
# http-request set-header Host demo.piesocket.com
# http-request set-path /v3/channel_1?api_key=oCdCMcMPQpbvNjUIzqtvF1d2X2okWpDQj4AwARJuAgtjhzKxVEjQU6IdCjwm¬ify_self
server websocket1 demo.piesocket.com:443 verify none redir wss://demo.piesocket.com/v3/channel_1?api_key=oCdCMcMPQpbvNjUIzqtvF1d2X2okWpDQj4AwARJuAgtjhzKxVEjQU6IdCjwm¬ify_self
# server websocket1 demo.piesocket.com:443 verify none
